Got my Pistons and cylinders
- Buda
21 Apr 2010 14:06 #362183
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Got my Pistons and cylinders was created by Buda
Got my stuff back form APE would take pics but I cant find the camera. 1170cc 10.25-1 comp pistons :woohoo: :woohoo:
:woohoo: :woohoo: :woohoo: Goin to the garage.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Samwell
- Thank you received: 1
21 Apr 2010 14:10 #362185
by Samwell
Replied by Samwell on topic Got my Pistons and cylinders
Buda wrote:
Its a great feeling to see the box just waiting for you in the garage! Have fun.
Tom
- otakar
21 Apr 2010 14:29 #362187
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Got my Pistons and cylinders
I hope that with the 1170 kit you got the block re-sleeved. If not the engine will run very hot on the street. this is why I decided to go with a 1150 kit. It leaves the sleeve walls quite a bit thicker, and the engine is much more reliable. If you got new sleeves that is the best because now the walls are even thicker and the engine is as reliable as stock.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Buda
22 Apr 2010 15:59 #362446
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic Got my Pistons and cylinders
No new sleeves just had the 1100 block bored. Ive got a good sized oil cooler hopefully it will help keep it cooler.
Just thinkin would 5 cc's per cylinder make that big of a difference in wall thickness?
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
