GAS IN OIL
- csrjoe
15 Apr 2010 21:11 #360998
by csrjoe
GAS IN OIL was created by csrjoe
HOW CAN GASOLINE GET INTO THE OIL OF THE ENGINE, I'M HAVING THE OIL CHANGED BUT STILL WOULD LIKE TO KNOW HOW.
- Thank you received: 2098
15 Apr 2010 21:17 - 15 Apr 2010 21:26 #361002
by Patton
Replied by Patton on topic GAS IN OIL
Usually traceable to faulty carb function which allows fuel to rise up too high inside the carb for whatever reason.
Last edit: 15 Apr 2010 21:26 by Patton.
- PLUMMEN
- Thank you received: 104
15 Apr 2010 21:19 #361004
by PLUMMEN
Replied by PLUMMEN on topic GAS IN OIL
common occurance on a 2 stroke engine,not so good on a 4 stroke though! :laugh:
- Buda
15 Apr 2010 21:22 #361005
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic GAS IN OIL
Needle and seat not sealing...floats set to high? Someone will give more detail answers.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- timebomb33
15 Apr 2010 21:25 #361007
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic GAS IN OIL
flaot valves pitted or scored will do that every time
15 Apr 2010 21:39 #361014
by Patton
Or a speck of grit or crud preventing complete seal of float needle tip inside the seat orifice.
Or maybe a leaky float, or "sticking" float, or loss of float buoyancy.
And sometimes floats get installed upside down. :pinch:
Likelihood of fuel intrusion into crankcase is increased when carb overflow circuit doesn't exist or is obstructed.
- H1Vindicator
- Thank you received: 47
16 Apr 2010 04:36 - 20 Feb 2013 20:06 #361034
by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 20 Feb 2013 20:06 by H1Vindicator.
- Thank you received: 2229
16 Apr 2010 06:28 #361074
by TexasKZ
Replied by TexasKZ on topic GAS IN OIL
A faulty petcock may also be adding to the problem, but not causing it.
- pgboyd
16 Apr 2010 06:38 #361079
by pgboyd
Phil Boyd
Northern Virginia USA
1995 KZ1000P Police Bike
Replied by pgboyd on topic GAS IN OIL
On the KZ1000Ps, a leaky petcock plus float valves that don't close leads to gas in the oil. Not uncommon to need to rebuild the petcock or replace with a shutoff. As a stopgap, you may find that putting the petcock on reserve instead of main may work to stop the fuel flow when the bike is not running. If your petcock has a PRI (prime) setting, don't leave it on this or you're asking for gas in your oil.
Phil
Phil
Phil Boyd
- csrjoe
16 Apr 2010 10:40 #361142
by csrjoe
Replied by csrjoe on topic GAS IN OIL
THANKS EVERYONE FOR THERE INPUT. TO ANSEWER ONE ? THOUGH, I WASNT GOING TO HAVE THE OIL CHANGED. THE PO SAID HE CHANGED THE OIL RECENTLY. BUT THE MECHNIC SAID HE SMELLED GAS IN OIL. IT COST 10 BUCKS. THE PO ALSO REPLACED THE PETCOCK, WITH NEW ONE. THE MECHNIC ALSO FLUSHED THE CARBS AND ALL 4 DID WHAT THEY WERE SUPPOSED TO DO, WHICH IS GAS CAME OUT. NOW THEY STILL MAY NEED TO BE CLEANED AND REBUILT I DONT KNOW BUT IT IS A ? I WILL ASK.
- JMKZHI
- Thank you received: 48
16 Apr 2010 12:21 #361155
by JMKZHI
Replied by JMKZHI on topic GAS IN OIL
All caps is kinda hard on the eyes & implies shouting.
- csrjoe
16 Apr 2010 13:06 #361157
by csrjoe
oops sorry, I'm not shouting, still learning how to use computer ligo
