- Thank you received: 3
aircooled gixxer 11OO
- 9am53
- homebrew, and some bbq
www.suzukicycles.org/GSX-R-series/GSX-R1100.shtml
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- otakar
From looking at the eBay thread I saw that GSX1100R, I went and did some research on it, and the last example of the old school aircooled bike was in the early 90's I believe. This bike had almost 150 hp!!! Is it strichtly the 16 valve motor that gives this bike so much more power than the 85 GPz11? or am I missing something
The GPZ1100 was rated at 120HP at only 8700rpm. The HP gos up exponentially with RPM. Plus there was a lot of embellishment on the HP ratings back than.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- 9am53
gixxer
Compression: 11.2 : 1
Bore x stroke: 75.5 x 60.0 mm
GPz
Bore x Stroke, Ø72.5 mm x 66.0 mm
Just looking at the stroke ratio the gixxer is more oversquare...I guess it's just an all around more modern aircooled bike, but I would guess the GPz would sound better
'84 GPz900r
'71 CB350
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- 9am53
'84 GPz900r
'71 CB350
- testarossa
doesn't oil cooled just mean the same thing as air cooled though? I suppose that you are right about the rpm though...
The GSXR's actually have a factory installed oil cooler, like a radiator. Just like you would have as an aftermarket oil cooler on your KZ when you build a higher displacement, hotter running engine.
X2 for everything that otakar says about oversquare. Look at a formula one engine some time.
2004 ZX-10R
Angola, IN
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
That oil cooler is about the same size as a radiator on a modern bike. It is huge.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Kraz1
Available as the Bandit 1200 until 2006. Dale Walker had 150 at the rear wheel, and there were a lot more fellows running bigger numbers than that. Dales' is a Street Bike.
150 HP @ 96 ft-lbs torque at rear wheel (best dyno pull) 1/4 mile 9.70 ET., 141 mph...
www.holeshot.com/b12project/index.shtml
- PLUMMEN
- Thank you received: 104
id say 150 hp stock is pretty optimistic,maybe 130ish.From looking at the eBay thread I saw that GSX1100R, I went and did some research on it, and the last example of the old school aircooled bike was in the early 90's I believe. This bike had almost 150 hp!!! Is it strichtly the 16 valve motor that gives this bike so much more power than the 85 GPz11? or am I missing something
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
