Which KZ 550 Would be the Best Deal?
- dlarnold
04 Apr 2010 14:41 #358401
by dlarnold
Which KZ 550 Would be the Best Deal? was created by dlarnold
I have opportunity to purchase a 1980 KZ550 Ltd with 15,000 miles for $800 or a 1984 KZ550 Ltd with 40,000 miles for $1,000! Which would be the best deal and why?
Both look good and are in "good running condition"
Thanks
David
Thanks
David
- KawiConvert
- Thank you received: 4
04 Apr 2010 20:13 #358465
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic Which KZ 550 Would be the Best Deal?
1980, fewer miles and 200.00 never hurts. If both are in similar condition and run well, the most you can hope for is a .5hp upgrade between the 80 and 84, and that will be gone after 40k miles anyways.
- loudhvx
- Thank you received: 1616
04 Apr 2010 23:17 #358487
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Which KZ 550 Would be the Best Deal?
THe 84 will have the CV carbs which are hard to get parts for. Also, if the diaphragms are torn, they are like $100 each. The 1980 LTD carbs are super simple and plentiful on ebay. They are also much easier to jet if you change the exhaust etc. You can get rebuild kits easily and can even get a upgrade kit from Dynojet for the 1980.
The electronic ignition is cheaper and simpler on the 1980 and easier to get parts for.
Is the 84 shaft or chain? Shaft will be more expensive to fix if it needs work, but I don't know if they typically do.
If they both appear to be in about the same condition, I'd get the 1980. But look closely for any frame alignment issues to make sure one wasn't in a crash etc.
1981 KZ550 D1 gpz.
Other links.
- H1Vindicator
- Thank you received: 47
05 Apr 2010 07:47 - 20 Feb 2013 19:15 #358518
by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 20 Feb 2013 19:15 by H1Vindicator.
- dlarnold
05 Apr 2010 09:03 #358529
by dlarnold
Replied by dlarnold on topic Which KZ 550 Would be the Best Deal?
Thanks all.
