kz750 twin?
- tlewis
02 Apr 2010 23:37 #358067
by tlewis
kz750 twin? was created by tlewis
I have the chance to pick up a very clean 79 kz750 twin pretty cheap. I know nothing about these bikes. What should i look for? I know the brakes r bad and it leaks gas. Son i got carbs and a brake job. what's a fair price for this model?
- Mcdroid
- Gone Kwackers
- Thank you received: 316
03 Apr 2010 03:26 - 03 Apr 2010 03:31 #358072
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic kz750 twin?
tlewis wrote:
At the risk of being trite...the 'cheaper the better' is a nice motto. That said, the 750 twins have not appreciated in value like their sister 4 bangers have. So, you should be able to pick up a running, nicely restored KZ750 twin for less than US$2000. I seem to recall seeing some 750 twins that have been highly over-valued...and they usually don't sell. Figure that you'll have to pump several hundred dollars into the bike to make it roadworthy and negotiate accordingly.
You might also post this same question on kz750twins.com/ It is a forum run by a fellow 'named' Biquetoast who is knowledgeable and has been helpful.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 03 Apr 2010 03:31 by Mcdroid.
- tlewis
03 Apr 2010 20:21 #358270
by tlewis
Replied by tlewis on topic kz750 twin?
Thanks for the info. I will check that site out.
- KZQ
- Administrator
- Thank you received: 1409
03 Apr 2010 21:10 #358279
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic kz750 twin?
tlewis wrote:
Depending on the mileage I'd say $850 to $1,100.
I have a 79 B4. Just had it repainted back to original specs.
The starter clutches are weak. I just disabled mine and use the kick start.
Good Luck
Bill
Good Luck
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
