first bike where do i start
- ditchdriver
26 Mar 2010 18:10 #356402
by ditchdriver
1982 kz 550 ltd
Grand Forks, ND
first bike where do i start was created by ditchdriver
im getting a 1982 kz550 ltd for $400 and it has been setting a year and a half i was just wondering if anyone has any suggestion on what i need to do before i start it its been covered in a garage he says it runs fine the carbs just need cleaned. any suggestions.
1982 kz 550 ltd
Grand Forks, ND
- Bad Dad
26 Mar 2010 19:04 #356416
by Bad Dad
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
Replied by Bad Dad on topic first bike where do i start
After sitting a year and a half, it probably needs a battery, it could use some fresh gas (I'd drain the tank & carb float bowls) oil change and fresh spark plugs. Run some Seafoam gas treatment in the first few tanks of gas, lube the chain and all the cables.
Safety equipment... must have good gloves and a helmet!
Ride safe, have fun!
76 KZ900LTD
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- Old Man Rock
- Thank you received: 225
26 Mar 2010 19:10 #356420
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic first bike where do i start
DO nothing for the time being...
Obtain a service manual.
Read & study service manual.
Get to know the ins & outs of you're new KZ.
Then go after whats wrong with her... Translation, if you know what it's supposed to do then troubleshooting the cause is a hell of a lot easier...
In the back of the OEM service manuals, they provide a fairly efficient troubleshooting guide.
Assuming the engine isn't siezed...
Insure a good charged battery.
Insure oil is filled to specs.
Fresh gas and the tank isn't full of rust.
At least check carb float bowls aren't all gunked up.
New plugs.
Try to start her then go from there.
New plugs.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- KawiConvert
- Thank you received: 4
26 Mar 2010 19:10 #356421
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic first bike where do i start
Change the oil and filter, clean/replace the air filter, pull the carbs and clean them thoroughly. Lube cables, check brakes for proper operation, tighten the cam chain, check your points (if it has them), check for spiders, check the tires, wear a helmet, wear a jacket, wear long pants, wear boots, wear gloves, wear out the tires and repeat.
- ditchdriver
26 Mar 2010 19:29 #356433
by ditchdriver
1982 kz 550 ltd
Grand Forks, ND
Replied by ditchdriver on topic first bike where do i start
thanks guys
i noticed they have 4 different carbs and ive looked at the forums for some info about them and got some good insight but anything special that i might need to look for when cleaning that a manual wont have in it.
1982 kz 550 ltd
Grand Forks, ND
- ditchdriver
26 Mar 2010 19:31 #356437
by ditchdriver
1982 kz 550 ltd
Grand Forks, ND
and i still have like a month before i get it so i have time to go over the manual any ideas where i could get one for cheap or nothing (like a .pdf)
1982 kz 550 ltd
Grand Forks, ND
- sm0kinace
27 Mar 2010 19:00 #356614
by sm0kinace
Carb Cleaning 101
Carb Cleaning 102
there is also a picture around here somewhere outlining simple clean that involved spraying in some holes and plugging some others up...maybe somebody knows where it's at else i'll have to get back after i find it again
as far as the manual some internet searching may turn one up...i found an pdf owner's manual for my 650 at kz650.info, i'm sure there's one for your 550 somewhere
1978 KZ650
Ichyta, KS
Replied by sm0kinace on topic first bike where do i start
1978 KZ650
Ichyta, KS
- sm0kinace
27 Mar 2010 19:09 #356616
by sm0kinace
1978 KZ650
Ichyta, KS
1978 KZ650
Ichyta, KS
- ditchdriver
28 Mar 2010 07:53 #356689
by ditchdriver
1982 kz 550 ltd
Grand Forks, ND
thanks smokin i appreciate the help i was on yesterday and looking and found an owners manual in .pdf so that will help. again thanks guys
1982 kz 550 ltd
Grand Forks, ND
- trianglelaguna
- Thank you received: 235
28 Mar 2010 08:08 #356694
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic first bike where do i start
now those are fun bikes..maybe the funnest bikes ever!!!!mine was an urban assault tool...i could do more/better on that bike than on bigger bikes....no fuss engines,no fuss handling,great bike...air pressure in tires is a great place to get your bie to suit your riding, settings right..people vary on their preffered p.s.i...i like 34-36 with 36 in the back...but find a base setting and go up and down 2 psi between rides.till your happy.....great bike...welcome....
1976 KZ900
2003 ZX12R
2007 FZ1000
