found my vintage! got questions
- Bad Dad
15 Mar 2010 13:45 #353666
by Bad Dad
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
Replied by Bad Dad on topic found my vintage! got questions
ninjaracerchick wrote:
Not that bad... especially for three hundred bucks - I say get it! Looks to be a complete, un-molested (stock) bike. Let us see the other pic's...
whatcha think?
76 KZ900LTD
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- ninjaracerchick
- Thank you received: 1
15 Mar 2010 13:50 #353667
by ninjaracerchick
its sex drippin on the pavement when we ride!
81 kz650csr "evelynn" my newest oldest ride choppy chop
06 zx-10r "felicia" my regular rider n track lady
01 zx-6r "vanessa" my 1st child n now streetfighter
Replied by ninjaracerchick on topic found my vintage! got questions
- jeffasaki
- Thank you received: 44
15 Mar 2010 14:31 #353669
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic found my vintage! got questions
Welcome Ninja Chick.Go buy that bike if you dont I will.IT RUNS!!!!.The rest can be sorted out.Lots of GOOD help here.(Just kidding.I wont go buy it)But if I had that deal anywhere close to my local Id be all over it.
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Bad Dad
15 Mar 2010 14:32 #353670
by Bad Dad
76 KZ900LTD
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
Put a Cafe style seat/tail piece combo, superbike bars (unless you really like the clubmans) and clean'er up... and you'll have an old school Cafe Racer. Of course, when you can afford it -- new tires, shocks and a fork brace will have it handling/looking better. You already have other bikes that really handle & go fast, so I'd stop there.
heres a full shot
76 KZ900LTD
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- kawsakiman
- Thank you received: 6
15 Mar 2010 15:19 #353681
by kawsakiman
Replied by kawsakiman on topic found my vintage! got questions
btw, those are mikuni slide carbs there. on a 650 they should be 24's
not to hard to clean at all but you will need more then a can of carb clean. got to assume that's all the po did was spray them down.
make sure all the passeges are clean. compressed air is great for this.
get it that far and we can walk you through the rest.
- mastermudd
15 Mar 2010 16:27 #353694
by mastermudd
Replied by mastermudd on topic found my vintage! got questions
check the fuel filter. it may be getting rust from the tank and reclogging the jets. i've had it happen on a kz650 i had a few years ago. i had to replace the filter twice before it finally cleaned out a little.
- timebomb33
- Thank you received: 10
15 Mar 2010 17:05 #353704
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic found my vintage! got questions
grab it the pipe it has would be worth close to that if it's in decent shape.
- jeffasaki
15 Mar 2010 17:12 #353706
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
The carbs are mikuni vm 24mm roundslides.you can tell buy the ribs.When i have to deal with a set of carbs that have been sitting forever.I take them apart,not a complete DA I leave the bodies attached to the frame.take out all jets screws and anything that has to do with air or fuel passages.I usually leave the mechanical parts on the top alone.after Ive DA,D them to the point where all fuel and air passages are expossed.I get a big pot of water boiling and throw em in and let em boil away for a couple hrs,then take em out blast away with 100 psi air,then throw em back in and repeat until the juices run clear.After cleaning I baist with some WD40 and again with the air.IF these carbs have been sitting forever the floats may have old fuel/water in them youll be able to tell just buy shaking them and listening if you hear shlosh thier done(however they can still be repaired).I cooked up a nice set of 24 mms for christmas dinner and my family just loved them.However I kept a wouderful set of 29mm mikuni smoothies for me and the wife to share.I love the vintage stuff
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- JMKZHI
- Thank you received: 48
15 Mar 2010 18:05 #353722
by JMKZHI
Replied by JMKZHI on topic found my vintage! got questions
The 1981 KZ650-CSR came stock w VM24 accel pump carbs.
But it didn't have the kickstarter: maybe someone added it.
You can check the engine number at the KZ650 Info website.
KZ550-Ltd cast alloy wheels are a direct bolt-on. You can swap the complete wheel/hub assemblies, or just get the 550 rims & front disk, then use everything else from your CSR.
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
17 Mar 2010 05:32 #353984
by riverroad
Replied by riverroad on topic found my vintage! got questions
Ninjachick, what you called rust on the engine is actually fuel residue, indicating one or more float needles aren't sealing properly. That stain will wash right off if you spray it with carb cleaner.
Looks like a good project! Have fun!
- z650c3
17 Mar 2010 06:32 #353995
by z650c3
1979 z650 c3 first registered in 1981
2006 Harley Davidson VRSCR
Northern Ireland
Replied by z650c3 on topic found my vintage! got questions
Grab that bike as fast as you can . Here in the UK on ebay 2 sets of carbs in reasonable looking condition fetched around $100 each 2 days ago . That bike in that nick over here would set you back around $1000 .
Go for it before someone else does and enjoy .
C3
C3
Northern Ireland
