- Thank you received: 4
XS750 Triple, Worth Restoring?
- KawiConvert
07 Mar 2010 21:27 #351892
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
XS750 Triple, Worth Restoring? was created by KawiConvert
Recently acquired a 1977/8 XS750 triple and wondering if there is a great need to bring this bike back from the grave. I have no attachment to it and already have enough projects to stay busy for the next 3 years, but want to make sure that I wouldn't be committing a sin by taking it to the local auto recyclers yard. Any ideas?
It is in rough shape with lots of surface rust, sun baked plastics, and from what I understand a smoked engine. That covers most of my concerns. When I first saw the triple pipe I thought maybe I'd found a 2-smoke and then this wouldn't be an issue, but as it is I have less interest in it. Anyways, thoughts and ideas appreciated.
- Russ Jackson
- Thank you received: 1
08 Mar 2010 04:36 #351920
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic XS750 Triple, Worth Restoring?
I had an 850xs triple shaft drive for a few years and it was a great bike. I would take another. Plus the old 3 cylinders have a little following now and are starting to increase in value. You should give it to someone as a first project. If it is fixable then I would find someone that wants a project...Russ
