swing arm bushings for my kz900a5
- wildwilly30
22 Jan 2010 05:11 #343887
by wildwilly30
1977 kz1000 chopper
1974 honda cb750k chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
1981 yamaha 650 special
1983 kawasaki vulcan
1977 hd sportster chopper
1987 honda vt1100c shadow
swing arm bushings for my kz900a5 was created by wildwilly30
anybody have a lead on some swingarm bushings for a kz900? i need the ones that go over the swingarm bolt. i replaced the press in bushings but wanna do the others while its apart. holding up my restoration. i see z1 enterprises had them but there out, bike bandit is out also.
1977 kz1000 chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
- Old Man Rock
- Thank you received: 225
22 Jan 2010 05:19 #343890
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic swing arm bushings for my kz900a5
Roller bearings or Complete kit...
Z1
www.z1enterprises.com/detail.aspx?ID=215
www.z1enterprises.com/SearchResult.aspx?...ue&KeyWords=swingarm
AmericanClassix
americanclassix.com/kawa_maintenance.html
Redline...
www.redlinecycle.com/Swingarm%20Kit%20-%20900.html
Not sure if APE has them or not....
Z1
AmericanClassix
Redline...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- wildwilly30
22 Jan 2010 15:28 #343979
by wildwilly30
1977 kz1000 chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
Replied by wildwilly30 on topic swing arm bushings for my kz900a5
not wanting the needle bearings, want the old solid bushing with the grease pockets cut out
1977 kz1000 chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
- Thank you received: 2829
22 Jan 2010 15:45 #343983
by 650ed
Replied by 650ed on topic swing arm bushings for my kz900a5
According to Ma Kaw the KZ900-A5 Bushing, Swing Arm - Part #33033-009 is still an active (available) part. Looks like they run around $45 each. Ed
- RonKZ650
- Thank you received: 240
22 Jan 2010 16:09 #343989
by RonKZ650
Replied by RonKZ650 on topic swing arm bushings for my kz900a5
The bushings are available, but the sleeves are not. These are the part with the worm groove to hold grease. If you replace the bushings you also need to replace the sleeves. If not replace, at least manicure the old ones so they slide into the bushings.
