Points Cover KZ650
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Points Cover KZ650
14 Jan 2010 15:40
#342893
That's nice!
I got this plastic one on ebayUK:
No fitting issues with it or the '78 original when used with a later model's factory electronic ignition.
Powder Keg made this points cover on his 650:
He also had ports/windows in the tank to check gas level;
And was working on a clutch cover:
T_Dub, if you can make points and other covers, you could have a good market for them here. B)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • T_Dub
  • T_Dub's Avatar Topic Author
14 Jan 2010 16:00 - 14 Jan 2010 16:05
#342895
If I make the points covers that'll be it, at least until I get out of school and save up for my CNC. Then I'll be making all sorts of things!
But if anybody has any special requests over the next 8 months, I'll try and make some stuff. I'm going to be making billet triple trees and clip ons for my 650 this winter too. I'll keep you all posted once the projects begin. I'm sure if anybody is interested in the parts I make I can do a limited amount of extras. The main project will be throttle bodies so I can do fuel injection.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Last edit: 14 Jan 2010 16:05 by T_Dub.
  • T_Dub
22 Jan 2010 11:37
#343946
So, I cut the cover out of foam today on the cnc, because its a bit finicky and I havent used it in a while. But, if cut out great! So I'm gonna cut it out of aluminum on Monday and I'll get some pics up of the process and the finished product!
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • pburnhamb
  • pburnhamb's Avatar
29 Jan 2010 11:53
#345258
nice! good luck! i cant wait.
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
  • B-Kaw
  • B-Kaw's Avatar
09 May 2019 19:44
#803619
Hi T_Dub,
I'm new to this forum and can't tell how old this post is but wondering if you had success building your points cover? It's my turn to need one and cant seem to find one.
  • TexasKZ
  • TexasKZ's Avatar
09 May 2019 19:55
#803622
The last post was January 2010.
09 May 2019 20:05 - 09 May 2019 20:06
#803624
B-Kaw wrote: Hi T_Dub,
Take a look again at his post. Ed
Last edit: 09 May 2019 20:06 by 650ed.
  • TexasKZ
  • TexasKZ's Avatar
09 May 2019 20:21
#803625
Ed,
When reading posts on a phone, those dates are not visible.
The following user(s) said Thank You: loudhvx, 650ed
09 May 2019 20:35
#803626
TexasKZ wrote: Ed,
Thanks! Ed
  • martin_csr
  • martin_csr's Avatar
10 May 2019 04:19 - 10 May 2019 12:09
#803628
No eBay APP ID and/or Cert ID defined in Kunena configurationBy B-Kaw: I'm new to this forum and can't tell how old this post is but wondering if you had success building your points cover? It's my turn to need one and cant seem to find one.
Here's one from a KZ550. It's the same as the 81 KZ650 & may fit the same as the 70s 650s since the 550/650/750-4 models use the same gasket. I have one FS that I refurbished. PM if interested.
Last edit: 10 May 2019 12:09 by martin_csr.
  • loudhvx
  • loudhvx's Avatar
10 May 2019 10:45 - 10 May 2019 10:48
#803646
They are backward compatible, but not always forward compatible. I really wanted to use a 77 Kz650 cover on my 550, but the electronic ignition parts must be a tiny bit taller than the points equipment. I couldn't get the cover to sit flush without contacting parts underneath.
Last edit: 10 May 2019 10:48 by loudhvx.
