- Thank you received: 235
timing lights ,any prefrences and why????
- trianglelaguna
Do folks have any favorites and can you give names ,reasons ect....or will any old timing light work as well as a fancy more $ one??...
I plan on buying the best one i will ever need for cars and bikes and want to get a good sturdy one and a one time purchase.....
Oh and i want a carb sync sticks too...any tips there would be helpful ..thanks ,,,craig..
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- keith1
so i bought a cheap timing light ...real inexpensive at a "freight" store and it's strobe kinda shows up inside my timing housing ...but kinda does'nt ...which is not so good when your a low skill level mechanic like i am, i would dig a btter /stronger pulsing light.....
craig,
i m a knuckle-dragger and the "freight cheapy" gets the job done.....as far as carb synching, i bought a set of guages off ebay,i think it was like a 100 bucks....i m all for z-1 , and have bought a LOT from them, but when it s the same set for a lot less, well, the loyalty is in the wallet.......just my .02......
- bill_wilcox100
- Thank you received: 5
However, I did buy a new chromed 4-Gauge set of Vacuum Gauges. They worked very well for me and I found them easy to use. The results were beyond my expectations.
Best of success.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
- KZ250LTD
- Thank you received: 16
79 KZ1000ST
Past:
Many.
- Martynbiker
- 1993 KZ1000P
I had a set before they were stolen and they even have
an adjustment to slow the vac pull down so the guage dampens and doesnt fluctuate wildly.
the best set I have ever used. well worth the $100
cgi.ebay.com/ebaymotors/Carburetor-Synch...5fAutomotiveQ5fTools
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
- keith1
Get a set of these carb synch Guages, I have seen em on sale at over $200 for the exact same ones.
same set i have from the same place...that guys prices arent too bad...i bought 3 or 4 things from him...
- loudhvx
- Thank you received: 1616
Sometimes those types care which way you clamp the plug wire. If it doesn't work one way, flip the clamp over.
I use a Sunpro timing light with a built-in timing knob. For most old cars and KZs, you don't need the timing knob, and in fact, it can mess you up if the knob gets bumped without you knowing it.
Also, the degrees on the timing knob do not correspond to crank degrees on the KZ.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Tony
- Thank you received: 13
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Actron Digital - love it.
A Morgan Carbtune Pro for syncing.
There's no subtitute for either in my mind.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- PLUMMEN
- Thank you received: 104
- fixer5000
1978 kz650b pretty much stock
massachusetts
- Old Man Rock
- Thank you received: 225
I started with the analog gauges but the fluctuations caused concern.... Confirmed with the Morgans, yup, where not to spec as expected.... Pay the extra $50 and you'll see the difference...
Timing lights cheap or expensive, will work fine... I use the HF tools with Advance feature... $30 You can set the light for accurate advance degreeing.
"Set timing advance without a degree scale on your engine. Simply set the advance on the timing light and align the timing mark to the TDC indicator on your engine."
www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40963
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
