- Thank you received: 3
scottoiler?
- 9am53
- homebrew, and some bbq
01 Dec 2009 06:21 #336829
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
scottoiler? was created by 9am53
anybody use one? seems like a good idea
'84 GPz900r
'71 CB350
- timebomb33
- Thank you received: 10
01 Dec 2009 07:54 #336840
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic scottoiler?
unless your riding in the wet all the time not really needed. the o-ring and x-ring chains are so good at keeping the oil or grease in the between the pins and bushings nowdays i wouldn't bother with the extra expense or the mess that happens when you use a chain oiler.if your using standard non-oring chain then it may be a good idea.
- 893cv
- Thank you received: 15
01 Dec 2009 19:27 #336985
by 893cv
1980 kz1000 LTD
1978 Z1R
Replied by 893cv on topic scottoiler?
Yes, I have one on my FJ1200. They do work, but they also can make the rear wheel very dirty. One of my friends used one and got over 50K from one chain and sprocket set.
You should also look at a Hawkoiler, its a push-button chain oiling system. I like the idea of controling the oil flow myself.
www.hawkeoiler.com
Ride Well,
Jon
www.hawkeoiler.com
Ride Well,
Jon
1980 kz1000 LTD
1978 Z1R
- TeK9iNe
- What did you do!?!
- Thank you received: 28
01 Dec 2009 19:46 #336989
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic scottoiler?
I'm not really into carrying any weight that I don't really have to.
Like said, the chains out now are fantastic, and last a good long time with minimal maintenence.
A blast of PJ1 clear chain lube once a week/250miles, and your good to go.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Martynbiker
- 1993 KZ1000P
06 Dec 2009 19:11 #337861
by Martynbiker
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
Replied by Martynbiker on topic scottoiler?
TeK9iNe wrote:
Yeah im with you on that But i use Bel Ray white chain lube. It is a 'DRY' Lube and makes less mess than conventional sprays. Besides, checking your bike over and oiling chain gives you a chance to become more "intimate" with your machine and spot possible problems before they appear!
