- Thank you received: 18
A Couple of KZ650 Questions
- Kawickrice
30 Nov 2009 16:38 #336735
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
A Couple of KZ650 Questions was created by Kawickrice
I will be doing a frame swap and was wondering what is a good gear ratio for highway cruzing with a passenger, something that will not rev to the high heavens at cruzing speeds but also will not cause me to burn up the clutch leaving a stoplight with a passenger. Also I have a set of what I believe is a Jardine 4 into 2 exhaust. What jetting should I start with that will get me in the right direction? It has pods the Jardine exhaust and will have the dyna ignition and coils. Do I consider the Jardine exhaust stock for jetting, or do I consider it like a 4 into 1 for jetting? I am also in the need for a round master cylinder and a headlight bucket with the trim rings for a 77 KZ650 B-1
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- KZQ
- Administrator
- Thank you received: 1409
30 Nov 2009 17:02 #336736
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic A Couple of KZ650 Questions
"I will be doing a frame swap and was wondering what is a good gear ratio for highway cruzing with a passenger, something that will not rev to the high heavens at cruzing speeds but also will not cause me to burn up the clutch leaving a stoplight with a passenger."
Stock will work fine.
"Also I have a set of what I believe is a Jardine 4 into 2 exhaust. What jetting should I start with that will get me in the right direction? It has pods the Jardine exhaust and will have the dyna ignition and coils. Do I consider the Jardine exhaust stock for jetting, or do I consider it like a 4 into 1 for jetting?"
You will have to work through the jetting. Bolt it up and read the plugs.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- Kawickrice
30 Nov 2009 17:12 #336738
by Kawickrice
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic A Couple of KZ650 Questions
It has the stock ratio I think. It seems to rev high doing 70 MPH, I would like to get the RPM's down a little at 70 MPH
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- anarki650
- Thank you received: 5
30 Nov 2009 18:45 #336754
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic A Couple of KZ650 Questions
Does the exhaust have baffles or no? If it's got baffles and pods I'd start with 17.5 pilots, needles on the #4 (from top) clip, and 112.5 mains. If its got no baffles bump the main up to a 115.
If you want to lower rpms at cruising speed try going to a 40 tooth rear sprocket. Losing the 2 teeth should put you right about where you want to be I'm thinking.
09 Kawasaki ER6n
Omaha NE
