78 KZ650 with no electric start. should i buy?
- eddiewasthedog
11 Nov 2009 14:47 #332889
by eddiewasthedog
78 KZ650 with no electric start. should i buy? was created by eddiewasthedog
Hello everyone, new member here. I have found a 1978 KZ650 with under 10k on the clock that looks like its in really good shape. Runs great, new tires, everything seems to work fine. The only issue is that the starter clutch is slipping. The bike kickstarts fine however.
My question is should I buy this bike knowing the starter clutch is dead? its only $1000 (could probably get that down to $900). Will this become an issue only useing the kickstart? does it make starting it when warm difficult? Any others out there had only kickstart for any period of time with no problems? I know how to kickstart a bike, just never owned one without a electric starter as well.
I understand the starter clutch can be repaired but I am a novice mechanic at best, more of a tinkerer, and dont think I have the tools or the right space or skill to do the repair myself, and i've been told most shops wont touch it or charge outrageous prices to do the job. (side question anyone know what a shop would charge?)
Any information or advice would be helpful. Thanks
- Eddie
- Eddie
- TeK9iNe
- What did you do!?!
- Thank you received: 28
11 Nov 2009 15:24 - 11 Nov 2009 15:26 #332898
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 78 KZ650 with no electric start. should i buy?
The kick-starter will work fine for any situation, so long as everything is nice and clean. (Clean carbs, lines, gas, etc.)
They are quite robust and shouldnt really give you any trouble.
Rebuilding the starter clutch is really easy too, if you decide to do it down the road.
Cheers!
Get a manual! Get a manual! Get a manual! :laugh:
YOU WILL LOVE IT!
I never take my bike to a shop for anything.
Cheers!
YOU WILL LOVE IT!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 11 Nov 2009 15:26 by TeK9iNe.
- Kawickrice
- Thank you received: 18
11 Nov 2009 17:00 #332928
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic 78 KZ650 with no electric start. should i buy?
I think $1000 for a 650 with a broke starter is a little much. If you can get it a little lower because the starter is broke it will be that much better. Fixing it is relatively simple and you will get some help from this site if you run into some problems. my .02 cents
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Thank you received: 2829
11 Nov 2009 17:06 #332929
by 650ed
Replied by 650ed on topic 78 KZ650 with no electric start. should i buy?
Is it possible to post a couple pics?
- irish mike
- 79 kz 650 b3 rat rod
15 Nov 2009 09:09 #333846
by irish mike
Replied by irish mike on topic 78 KZ650 with no electric start. should i buy?
i bought my 79 as a project bike 4 400$-it needed alot of tlc-is the starter clutch the only issue-mine had 9600 miles on .one of the issues with mine[i found out after i got itr running] was the starter cluth but ifound that if i used the kick start to start it initially,later if i needed to started it again [while warm]it started with minimum slipage;if the bike is in otherwise good condition -isay buy it ,ilove my 650[remember theese are cool vintage bikes now]theese bikes are so easy to work on yourself as compared to todays bikes-you will have many miles of coolness on a kz650
