- Thank you received: 3
Formulas
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
Following are some of the most commonly used formulas useful for high performance work.
Displacement from Bore and Stroke
displacement = pi x (radius squared) x height
example: 4 inch bore, 4 inch stroke
displacement = 3.14159 x (2 squared) x 4 = 50.265ci per cylinder
Cubic Centimeters from Cubic Inches
cc = (2.54 cubed) x ci
example: 100ci
cc = (2.54 cubed) x 100 = 1638.7cc
Cubic Inches from Cubic Centimeters
ci = cc / (2.54 cubed)
example: 1200cc
ci = 1200 / (2.54 cubed) = 73.23ci
Horsepower from Torque and RPM
hp = (torque x rpm) / 5252
example: 80 ft-lbs at 4000 rpm
hp = (80 x 4000) / 5252 = 60.93hp
Torque from Horsepower and RPM
torque = (hp x 5252) / rpm
example: 100hp at 4000 rpm
torque = (100 x 5252) / 4000 = 80 x 4000) / 5252 = 131 ft-lbs.
Average Piston Speed from Stroke and RPM
average piston speed in fpm = (stroke in inches x rpm) / 6
example: 4 inch stroke at 6000rpm
aps = (4 x 6000) / 6 = 4000 feet per minute
Horsepower from Quarter Mile Speed and Weight
hp = ((mph / 223) cubed) x weight
example: 130 mph with a 600lb bike & rider weight
hp = ((130 / 223) cubed) x 600 = 118.8 hp
Horsepower from Elapsed Time and Weight
hp = weight / ((ET / 5.92) cubed)
example: 10 seconds ET with a 600lb bike & rider weight
hp = 600 / ((10 / 5.92) cubed) = 124.5 hp
Elapsed Time from Horsepower and Weight
ET = 5.92 x cube root of (weight / horsepower)
example: 650lb bike with 140hp
ET = 5.92 x cube root of (650 / 140) = 9.88 seconds
Quarter Mile Speed from Horsepower and Weight
mph = 223 x cube root of (horsepower / weight)
mph = 223 x cube root of (140 / 650) = 133.67mph
Elapsed Time from Quarter Mile Speed
ET = (1320 / mph)
example: 10 second bike
ET = (1320 / 10) = 132 mph
Quarter Mile Speed from Elapsed Time
mph = (1320 / ET)
example: 134 mph bike
mph = (1320 / 134) = 9.85 seconds
Flow Bench Test Pressure Conversion
Flow = (square root of (new flow pressure / known flow pressure)) x known cfm
example: 160 cfm @ 10", convert to 28"
Flow = (square root of (28 / 10)) x 160 = 267.7 cfm at 28"
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Bluemeanie
- Thank you received: 14
- OnkelB
- Thank you received: 80
Umm, seems to be a typo there (marked in red), I believe the last line should just read:
Torque = (100 x 5252) / 4000 = 131 ft-lbs.
77 KZ 650 B1, 82 GPz 1100 B2.
- arai59
- Banned
- Thank you received: 2098
That is VERY cool stuff. Saved it to file for future use!
Saving to file won't be necessary, as OMR will soon be posting all the charts. :laugh: :laugh:
Good Luck!
- hardr0ck68
- Who put the what in the where?
Good Luck!
Only if he can polish them to a mirror like finish first :blink: :silly: :silly: :blink:
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- kzz1p
It could be, I'm not a Math guy!
- PLUMMEN
- Thank you received: 104
Big bore x short stroke + right cam and carbs with a good head = lots of power!
:woohoo:
- KZQ
- Administrator
- Thank you received: 1408
you guys think way too hard! :laugh:
:woohoo:
Big bore x short stroke + right cam and carbs with good head = lots of power!
You got it going on there Fred, er I mean Jim.:laugh:
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- arai59
- Banned
