Mods for 1980 KZ750-E
- rayellis
17 Oct 2009 18:16 #328092
by rayellis
Mods for 1980 KZ750-E was created by rayellis
What are some of the best Mods for my 1980 KZ750-E 4 cylinder. I'm restoring the bike but will most likely keep it mostly the stock look. Willing to listen to any radical ideas.
I will change..
stock air box to individual pods
stock exhaust to 4to1 ????
Biggest width tires that will fit rims
Maybe a oil cooler
I here about changing the swing arm like from a GS1100 is this worth changing give me pros and cons?
What can I do to the engine? It looks like a rebuild of some kind at this point. I have a ring or valve leak so compression is not good. I here a 810 piston kit is not a bad idea.
What do you think?
Thank You
Ray
I will change..
Maybe a oil cooler
What do you think?
Thank You
Ray
- Thank you received: 2829
17 Oct 2009 19:16 #328121
by 650ed
Replied by 650ed on topic Mods for 1980 KZ750-E
Get pods if you want to become very familiar with carb removal and re-jetting.
- JMKZHI
- Thank you received: 48
18 Oct 2009 08:32 #328206
by JMKZHI
Replied by JMKZHI on topic Mods for 1980 KZ750-E
Superbike bars?
- zed810
29 Feb 2012 19:16 #507061
by zed810
1981 z750e1 gpz 750a1 tank and side panels 810 bore kit web cams mikuni bs34 vance and hines pipe
Replied by zed810 on topic Mods for 1980 KZ750-E
pods are fine, if you buy good quality ones (k&n etc) if running mikuni carbs (bs34s) 40 pilot 140 mains is a good start. 4-1 exhaust is lovely looking although makes the other side of the bike look a bit odd. 810 bore kit DOES make a big difference to the power and torque on these engines also takes the compression up to 10.25 or 10.5-1.
basically my 750e has all the above parts but with a set of web cams and orient express valve springs, runs flawlessly and dyno'd at 109bhp at the crank (89rwhp) lifts the front wheel on acceleration in the first three gears, out accelerates cbr1000 to 110mph i lift off at 145 when it starts to use both sides of the road and on a run gets 50+mpg and so far has done nearly 25000 miles with no problems.
29 Feb 2012 19:23 #507064
by 650ed
He hasn't posted in 9 months. I wonder if he put pods on it?
