- Thank you received: 3
I got a garage to work on the bike!
- 9am53
- homebrew, and some bbq
08 Sep 2009 04:22 #319824
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic I got a garage to work on the bike!
OK, so in preparation for this winters work I am starting to figure out what I will need to buy and an order for the work that I will do. I want to (among other things) replace the valve cover gasket, valve adjustment, manual chain tensioner, and replace the head gasket. Would it be best for me to adjust the valves, and then remove the cams and head? or should I take everything out, replace the head gasket and do the valve adjustment after it's back together?
'84 GPz900r
'71 CB350
- roy-b-boy-b
- Thank you received: 103
08 Sep 2009 06:12 #319836
by roy-b-boy-b
Replied by roy-b-boy-b on topic I got a garage to work on the bike!
You could do the adjustment first and keep every thing in order and run down the shims you need. Roy
- 9am53
08 Sep 2009 06:16 #319837
by 9am53
'84 GPz900r
'71 CB350
cool, so when I put everything back the valves should stay put right?
'84 GPz900r
'71 CB350
- roy-b-boy-b
08 Sep 2009 06:52 #319840
by roy-b-boy-b
If you are not going to do any head work or tear the head down i think this would be the way to go. Roy
- 9am53
08 Sep 2009 06:56 #319843
by 9am53
'84 GPz900r
'71 CB350
I am going to take the head off only so I can change the head gasket, and maybe do some cleaning, but I don't plan on doing any other work for now.
'84 GPz900r
'71 CB350
- Buda
08 Sep 2009 07:16 #319844
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic I got a garage to work on the bike!
When you replace the head gasket you will need to order the orings for the oil passages as they dont come with the gasket kit.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- 9am53
08 Sep 2009 07:28 #319849
by 9am53
'84 GPz900r
'71 CB350
thanks for the heads up, I didn't know that. I am going to make a thread in about a month aimed to help Newbs like me, so I hope to find these little tidbits along the way in that thread.
'84 GPz900r
'71 CB350
