- Thank you received: 3
suzuki swingarm question
- 9am53
- homebrew, and some bbq
19 Aug 2009 05:10 #314990
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
suzuki swingarm question was created by 9am53
Hi, I have read that many people swap the original KZ swingarms on their bikes for GS1100 units. I understand that this gives almost 2 inches length over the kz1000 arm. The GS units also look aluminum, are they lighter than the KZ swingarms? Would the added length make the bikes handling suffer much? I understand it would be better suited for dragging, but I would be afraid of the handling sucking...
'84 GPz900r
'71 CB350
- Z1109R Fin
- Thank you received: 1
19 Aug 2009 05:50 #314998
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic suzuki swingarm question
GSX swing is a pretty easy swap (if swapping ever is easy). I used to have a GSX1100 ´90 swing and it´s 2" 50mm longer than stock. It´s alu of course and much lighter. Makes the bike longer and therefore heavier to steer on twisties. On the other hand if you like drag-look thats what you get with it but I changed to ZRX11 ´99 swing. IMO it´s the one and only for an ELR
Check this topic: kzrider.com/index.php?option=com_kunena&...mit=20&limitstart=20
