What's the key?
- beazzzz
16 Aug 2009 06:15 #314279
by beazzzz
Then:
1966 Honda CB 160
1967 Honda CL 305
1970 Ossa 250
1971 Honda CL 450
1980 Suzuki GS 1100 ES
1984 Suzuki PE 175
Now:
1976 Kawasaki KZ900 (2nd owner)
1977 Honda 750 K Original Owner
1978 Honda 813 K (bored out)
2004 Triumph 900 Thruxton
What's the key? was created by beazzzz
I am hoping that someone has run into this problem and figured it out.
My ignition lost its mind last week on my 76 kz 900. When I turned the key to the off position the bike wouldn't shut off.I hit the kill switch, which shut off the engine but the headlight wouldn't shut off. I tried the headlight switch, but that wouldn't shut it off. I then disconnected the battery terminal which finally shut it all down. I checked wiring, fuses etc. and figured it was the ignition (original 33 year old part).So I ordered a new one from Rice Paddy (a real quick delivery too!) installed it and I still have the same problem.
So I'm stuck....any suggestions?
Thanks in advance for any input.
Then:
1966 Honda CB 160
1967 Honda CL 305
1970 Ossa 250
1971 Honda CL 450
1984 Suzuki PE 175
Now:
- Thank you received: 2829
16 Aug 2009 06:35 - 16 Aug 2009 06:36 #314285
by 650ed
Replied by 650ed on topic What's the key?
Sounds like a short. Try unplugging the ignition switch and reconnecting the battery to see if the problem persists. If it does, you will need to troubleshoot the wiring. Nice bike! Ed
Last edit: 16 Aug 2009 06:36 by 650ed.
- beazzzz
16 Aug 2009 06:46 #314290
by beazzzz
Then:
1966 Honda CB 160
1967 Honda CL 305
1970 Ossa 250
1971 Honda CL 450
1984 Suzuki PE 175
Now:
Replied by beazzzz on topic What's the key?
Thanks Ed...I've started down that road already.I haven't found anything yet,tho. But I'll keep you posted.
Then:
1966 Honda CB 160
1967 Honda CL 305
1970 Ossa 250
1971 Honda CL 450
1984 Suzuki PE 175
Now:
- beazzzz
13 Sep 2009 10:02 #321325
by beazzzz
Then:
1966 Honda CB 160
1967 Honda CL 305
1970 Ossa 250
1971 Honda CL 450
1984 Suzuki PE 175
Now:
Well Ed, you were right. After an afternoon in the garage I found the short. It was in the wiring harness up near the headlight. So I redid it and now I'm back on the road. Funny too,I had just passed 36k on the old girl and was thinking how reliable it was after 33 years (I've had it for about 3 years, bought from the original owner) I guess the Gods threw me a test to see if I really wanted to keep her running. Put 50 miles on it this morning and it ran just fine.
thanks again
Beaz
thanks again
Beaz
Then:
1966 Honda CB 160
1967 Honda CL 305
1970 Ossa 250
1971 Honda CL 450
1984 Suzuki PE 175
Now:
