How much is this KZ650 worth?
- KZ650ftw
28 Jul 2009 15:23 - 28 Jul 2009 15:27 #309909
by KZ650ftw
Bikes: CX500 Custom
Soon to be 79\\\\\\\' KZ650!!!
How much is this KZ650 worth? was created by KZ650ftw
I put my Honda CX500 up on craigslist and a guy emailed me that he had some bikes he would trade me. He has a KZ650 that has the specs I was looking for (duck tail, duel front/rear disk brake, alloy wheels) and I was hoping you guys could give me an idea of it's value so I have a better idea of this trade situation. I'm not sure yet how many miles the bike has on it, but here are a couple pics. I looked around and I believe it's a 77' KZ650 Custom, though he said it was a 76 and didn't know the model. He said it has a super trap muffler, and clearly it has pod filters and no kick start lever.
Bikes: CX500 Custom
Last edit: 28 Jul 2009 15:27 by KZ650ftw.
- KZ650ftw
28 Jul 2009 15:25 #309910
by KZ650ftw
Bikes: CX500 Custom
Replied by KZ650ftw on topic How much is this KZ650 worth?
Bikes: CX500 Custom
- anarki650
- Thank you received: 5
28 Jul 2009 15:47 #309913
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic How much is this KZ650 worth?
Someone once said, it's worth whatever you can get someone to pay for it. If it was me and the bike was running pretty decent I'd give up to about $700 for it. Missing the side cover and the kick start lever are great points to help you bring the value down on it if he's wanting too much for it. How well it runs is the deal maker/breaker. Take compression on it, if it doesn't have good compression you're looking at head/valve work (most likely unless it has ring issues) and top end gaskets. If compression is low I wouldn't give more than about $500 for it. If you can't tell I like the $1 a cc for a running bike theory...getting a little harder to get those kind of deals lately, but if you're shrewd you can still find them.
And you're right, it's likely a 77C model. Some of the 77's were sold as 76, so he may not be wrong on that.
If she's a decent runner I'd trade a CX500 for it, assuming the CX wasn't cherry.
09 Kawasaki ER6n
Omaha NE
- KZ650ftw
28 Jul 2009 16:01 #309920
by KZ650ftw
Bikes: CX500 Custom
The CX500 Custom isn't cherry, but it does run great and only have 5000mi on it. I don't know how to do a compression test on a bike, so I'll just have to go see how it runs. I was thinking it was probably a fair trade if his runs well.
Bikes: CX500 Custom
- anarki650
28 Jul 2009 16:19 #309924
by anarki650
09 Kawasaki ER6n
Omaha NE
Doing a compression test is super easy. You'll need a compression tester, should be able to get one inexpensively at any auto parts store around you. You pull all the plugs out of the bike (takes 2 minutes) and put the tester into each plug socket (some thread in some just press into the hole) one at a time. After putting the tester on hit the start button and crank the bike over until the compression gauges hits it's highest point, will usually max out after about 5-7 cranks, that's the compression for that cylinder. If the motor has lower than 150 per cylinder expect to do some work in the near future, and think about the trade a bit more...
09 Kawasaki ER6n
Omaha NE
- anarki650
28 Jul 2009 16:22 #309925
by anarki650
09 Kawasaki ER6n
Omaha NE
cgi.ebay.com/ebaymotors/PLEWS-TOOLS-COMP...lsQQsalenotsupported
something like this would be real easy to take with you to look at the bike too. If the guy objects to you checking compression on it I'd also think twice about bringing it home...
09 Kawasaki ER6n
Omaha NE
- eMusicMan
- Thank you received: 1
28 Jul 2009 16:29 #309927
by eMusicMan
Replied by eMusicMan on topic How much is this KZ650 worth?
Check out the Motorcycle section of the NADA Guides online (
www.nadaguides.com
)... I've used it many times and seems quite solid... I've definitely used the information when purchasing a bike from someone.
- quader98
28 Jul 2009 18:03 #309940
by quader98
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
Replied by quader98 on topic How much is this KZ650 worth?
to check compression , don't you have to hold the throttle wide open ?
82 GPZ 750 R1
- JMKZHI
- Thank you received: 48
29 Jul 2009 05:50 #310018
by JMKZHI
Replied by JMKZHI on topic How much is this KZ650 worth?
Yes - WOT... or when the carbs are off the bike.
Before removing the plugs, make darn sure there isn't any debris around them - like a pebble or screw or something. I always blow the area w compressed air prior to removal. Get a compression tester that has a 14mm threaded end or adapter.
- rstnick
- Thank you received: 377
29 Jul 2009 06:20 #310028
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic How much is this KZ650 worth?
Trade! Trade!
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
