Steering Stabalizer - know how to put it on? Is it
  • KOOL RYDER
  • Topic Author
  • KZ 650B2 / KZ 1000E
16 Jul 2009 13:32 #307414 by KOOL RYDER
Anyone know how to mount a steering stabilizer on a 650B?
Are they a good add on?
Thanks
KR B)
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
  • KZQ
  • Administrator
16 Jul 2009 13:41 #307418 by KZQ
I fitted a stabilizer to my KZ900 years ago and took it back off when I finally figured out that the head shake/wobble I was fighting was caused by worn swingarm bushings. I wouldn't imagine that the 650 is that much different in the frame geometry department.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
16 Jul 2009 23:31 #307512 by donthekawguy
Replied by donthekawguy on topic Steering Stabalizer - know how to put it on? Is
They sell brackets on ebay that bolt on to a fork leg and then you weld a piece on the frame to bolt it onto.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
17 Jul 2009 06:01 #307537 by Bluemeanie
Replied by Bluemeanie on topic Steering Stabalizer - know how to put it on? Is
Some go from the fork back to the right screw in reflecter hole on the down tube.
17 Jul 2009 06:06 #307540 by 650ed
Just curious - are you putting it on the bike to help compensate for an existing wobble or for some other reason? Ed
17 Jul 2009 06:27 #307546 by 1973Z
My '73 came stock with a bracket on the right hand frame down tube and a hole in the lower triple tree where the damper-s Kawasaki product itself-bolts right on. It's still there 36 years later and works just fine. It was the first accessory I installed when new, and I got it after some magazine articles at the time mentioned possible problems at high speed due to the frame being "under engineered" for the motor. I had it up to an indicated 125 mph once and it felt solid but I never took it up that fast again.
