Kawasaki Special Tools
- KZ650
23 May 2009 19:23
Other than EBAY or Kawasaki itself does anyone have any idea where I might be able to find the Special Tools as listed in the back of the Factory Kawasaki Shop Manuals. I looking for anything for my 1979 KZ650-B3. Thanks
- Mcdroid
- Gone Kwackers
Re: Kawasaki Special Tools
23 May 2009 22:32
The short answer is no. No one carries stocks of these tools (although
www.Z1Enterprises.com
does carry the valve shim tool). Most of us here have either fabricated whatever special tools we have needed or have patiently fought over the few that have appeared on eBay :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Mark Wing
24 May 2009 11:18 - 24 May 2009 11:19
Welcome to KZR, I'd say eBay and good luck. 650's are under bucket shims so they don't use the valve shim tool.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
Last edit: 24 May 2009 11:19 by Mark Wing.
24 May 2009 14:29 - 24 May 2009 14:29
I know you said "anything" but is there a particular tool you need ASAP for a project, or are you building up your tool arsenal for later projects? Ed
Last edit: 24 May 2009 14:29 by 650ed.
- hardr0ck68
- Who put the what in the where?
24 May 2009 16:06
There are many tools Kawi lists as special, there are few that actually are. The only "special" tool I bought is the carb fuel level thinggy, which could be replaced with a simple rubber tube.
If you don't have money to burn, I would wait till you HAVE to have one then ask folks here... 10 to 1 says there is a way to do the job without the tool!
Good luck, and welcome to the family!!
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- donthekawguy
24 May 2009 23:21
I went to a dealer and asked if I could by the ring compressor tool. They got all pissy and said it's a dealer only item. I found one on ebay for $80 so screw them. :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
