kz 650 hasn't been started in three years
- kzrt
15 May 2009 17:39 #291503
by kzrt
kz 650 hasn't been started in three years was created by kzrt
Hello everyone. I'm new to the forum and purchased a kz650 yesterday for 300 bucks. It hasn't been started in a few years, but I feel that it wants to. no rust in the tank, good battery power, and the pistons feel like their moving when I move the bike backward in second gear. I don't want to hurt the bike by firing it up right away. any thoughts, thanks, ryan
- Thank you received: 2829
15 May 2009 18:29 #291516
by 650ed
Replied by 650ed on topic kz 650 hasn't been started in three years
Change the oil and filter before starting and I'd shoot a little lite oil in the cylinders before hitting the starter. Fresh fuel of course and an inline fuel filter wouldn't hurt in case there's stuff in there you can't easily see. Once started, I'd let it warm up and change the oil & filter again to flush any old junk from engine. Once you get it running be sure to change the brake fluid & fork oil and lube the chain, cables, and any pivot points before riding it. (and check the tires) Good luck with it.
- FlickeredOne
16 May 2009 07:44 #291633
by FlickeredOne
'77 KZ 650 B1 / '74 Harley SX 125
Replied by FlickeredOne on topic kz 650 hasn't been started in three years
Ryan-Be sure to take a real close look at ALL of your gaskets!!! I had a few extra leaks after 3 years of sitting myself.
- baldy110
- Thank you received: 512
16 May 2009 18:46 #291764
by baldy110
Replied by baldy110 on topic kz 650 hasn't been started in three years
If it has been sitting for three years with gas in the tank and carbs then I would say the carbs are rally gummed up and will need a good cleaning. What does the gas smell like in the tank?
- RonKZ650
- Thank you received: 240
16 May 2009 20:00 #291786
by RonKZ650
Replied by RonKZ650 on topic kz 650 hasn't been started in three years
You can sit for 150 yrs and the gaskets don't care. Actually they are happy with the rest. Gas in the tank and carbs is another story.
