1979 KZ 1000 LTD vs MK-11
- Kingchiefa
- To each thier own.
Re: 1979 KZ 1000 LTD vs MK-11
15 Apr 2009 14:06
the color of the bike is green would that make it a 78?
1979 KZ1000 ltd b3 Currently in Troy, PA. Hope to some of you on the road.
- dman3998
15 Apr 2009 16:07
the 79 green is a really dark metallic, from a distance it almost looks black.
PICS we need PICS!
PICS we need PICS!
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- Jack
15 Apr 2009 16:38
Kingchiefa wrote:
The 78 KZ1000 did come in Metallic Green with Gold accent stripes on the tank & tailpiece. The 79 LTD green is much darker as previously said.The engine in a 79 or 80 LTD is the same as in the MKll( a good thing ) ,just not painted black.the color of the bike is green would that make it a 78?
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- RonKZ650
15 Apr 2009 19:13
Actually the 79 LTD used the old spec KZ1000 engine from 1978 complete with points ignition. It was 1980 the LTD was upgraded to the MKII type engine design.
- Kingchiefa
16 Apr 2009 06:21
OK, give me a just a min. I should have pics up.
- Kingchiefa
16 Apr 2009 06:23
Mcdroid wrote:
I got the vin number which numbers after the KZT00B supply the date?
Kingchiefa wrote:Mcdroid wrote:Better is a subjective term...check the frame VIN on the triple-tree neck...if the 6th letter is a 'B' than it is an LTD frame...if it is an 'A' then you have a MKII. Neither bike came stock with a fairing.
That sounds good, I will check. What does it mean if neither are on then VIN? I'm starting to feel like the bike is not what the guys says it is...
In 1979, Kawasaki released four KZ1000 models (KZ1000A3, the standard; KZ1000B3, the LTD; KZ1000E1, the Shaft; and KZ1000C, the Police issue). The 6th letter of the frame VIN will be either A, B, E, or C, in that order (to match the above order). The most common KZ1000 sold was the LTD model and it is likely that is what you have...the numbers after the frame KZTOOB will then determine what year bike you have.
- Kingchiefa
16 Apr 2009 06:27 - 16 Apr 2009 06:28This is the best pic i have at the moment I need to crop the other ones down, I'm going to throw up a front view also...( this is the pics I get for askign my girl to take them...) lmao
Last edit: 16 Apr 2009 06:28 by Kingchiefa.
- Kingchiefa
16 Apr 2009 06:30
- Mcdroid
- Gone Kwackers
16 Apr 2009 06:36
Kingchiefa wrote:
All of them...and you can also check www.zedder.com under 'bike info' to see if the motor VIN goes with the frame VIN to see if a engine swap is suggested. BTW, it looks like you have an LTD...nice bike.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Kingchiefa
16 Apr 2009 06:49 - 16 Apr 2009 06:53
Mcdroid wrote:
'79 KZ1000-B3:LTD that is my bike!!! Yeah now I know which model I have.
Kingchiefa wrote:I got the vin number which numbers after the KZT00B supply the date?
Last edit: 16 Apr 2009 06:53 by Kingchiefa.
- RonKZ650
16 Apr 2009 06:59
Yea it's a 79 KZ1000B3. Not the original paint or side covers, but looks nice. The way the ser # works is KZT00B5xxxxx, KZT means model is KZ, 00 means 1000, B means LTD, 5 means made in Lincoln, NB. 5 numbers after that are the serial number in sequence so 20000 would fall in the 1979 model year.
- Jack
16 Apr 2009 07:09
RonKZ650 wrote:
Not so sure about that...there are 2 1979 LTD's on Ebay right now ,both with MKll enegines...check out EBay items 320359272543 and 260393899816. Pretty sure 79 LTD's in Canada had MKll engines,I ripped one apart for dragbike parts.US models could have been different.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
