78 kz1000 carb sync;
- kawboy13
07 Feb 2009 20:45 #262821
by kawboy13
78 kz1000 carb sync; was created by kawboy13
I sent my carbs to WG and he set them up for my 78 kz1000 with K&N pods and a Mac 4 into 1. I want to sync my carbs after going through a normal tune up procedure and I'm wondering if the cm. of merc. on my gauge should be different from a stock setting. I hope some of you with this type of setup would respond, thanks a lot.
- Thank you received: 2098
07 Feb 2009 22:11 - 07 Feb 2009 22:15 #262835
by Patton
Replied by Patton on topic 78 kz1000 carb sync;
Imo, getting the columns to equal levels is the critical factor, regardless of intake/exhaust configuration.
Good Luck!
Good Luck!
Last edit: 07 Feb 2009 22:15 by Patton.
