zinc plating?
- wiredgeorge
30 Dec 2008 13:13 #255397
by wiredgeorge
zinc plating? was created by wiredgeorge
I really need to do some small scale zinc plating. Many of the small parts that get bead blasted to remove rust on carb assemblies I work on require replating to make them look nice. I have been using another plating source and they have gotten really expensive. Anybody on KZrider do any zinc plating? Willing to share tips/tricks and describe what is needed to start doing the plating? I have seen a couple "kits" which consisted of a battery pack and a couple leads, some acid solution and a couple pieces of zinc plus a couple brushes and cleaning compound. I have seen more professional looking "regulators" used for plating. Not sure what I need to buy to get started.
- Kawickrice
- Thank you received: 18
30 Dec 2008 13:35 #255406
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic zinc plating?
Check out the Eastwood catalog. They sell a plating kit.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- wiredgeorge
30 Dec 2008 14:46 #255414
by wiredgeorge
Replied by wiredgeorge on topic zinc plating?
Yeah, I know. A couple of small batteries with leads, the zinc in bar stock, some sulfuric acid in solution and some cleaner with a brush. $70. I expect I could buy the same stuff at a hardware store for a bit less... was wondering if this level of stuff would be right. I couldn't view their video on the subject... Notice they didn't supply a tank?
- kano
- Not Another Bloody Limey!
30 Dec 2008 15:57 #255428
by kano
Replied by kano on topic zinc plating?
i found this hope it helps loads of info on the subject no video sorry i looked everywhere.
www.pfonline.com/articles/pfdbiddulph01.html
- steell
30 Dec 2008 20:55 #255469
by steell
Replied by steell on topic zinc plating?
You might check out Caswell
www.caswellplating.com/kits/zinc.htm
They have a pretty active forum there also.
- H2RICK
- Is this a fun bike, or what!!!
31 Dec 2008 11:10 #255539
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic zinc plating?
A buddy of mine has the Caswell kit and he's pretty happy with the quality of plating it does. He does say, though, that most of the work IS in the preparation of the pieces i.e. cleaning properly, filing/smooting the rough bits, etc.
- dman3998
01 Jan 2009 16:26 #255710
by dman3998
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Replied by dman3998 on topic zinc plating?
150 bucks for the small kit!, but that would do most of the little hardware parts on a major rebuild. The only other solution I can come up with is paint and that is not Original looking and comes off easy on bolt heads.
My only question is how long can the chemicals "hang" around?
like I get the kit and do a couple dozen parts then I don't need it for 6 months is everything toast and I have to buy new chemicals even though I hardly used them up?
Monday I think a call to Caswell is in order.
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- kawtoy
- Thank you received: 6
02 Jan 2009 17:31 #255817
by kawtoy
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
Replied by kawtoy on topic zinc plating?
Eastwood video link. Looks like you have to hand polish everything after plating.
- arai59
- Banned
02 Jan 2009 18:37 #255825
by arai59
Replied by arai59 on topic zinc plating?
George, there is a plating company close by my shop. He does a bucket of parts, bolts, etc. for like $50. Can't beat it. He does clear zinc and yellow zinc.
- wiredgeorge
04 Jan 2009 14:05 #256153
by wiredgeorge
The problem would be turning stuff around and keeping track of it. I think I will do this stuff in house. I have some things to do first before taking on plating but will get it done some time this spring. I will likely go with a Caswell kit.
- Mellvis
- Thank you received: 3
04 Jan 2009 19:23 #256204
by Mellvis
Replied by Mellvis on topic zinc plating?
My brother does zinc plating at home. He is a member here also, Dreamsofaz1r. If you would like, I'll have him contact you when I see him next time.
- dman3998
04 Jan 2009 20:40 #256215
by dman3998
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
