- Thank you received: 1
conversion tables
- quader98
26 Dec 2008 07:35 #254716
by quader98
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
conversion tables was created by quader98
my torque wrench is ft/lbs and i need inch/lbs can i use this conversion table to remedy my problem???
www.onlineconversion.com/torque.htm
82 GPZ 750 R1
- mariozappa
- Thank you received: 8
26 Dec 2008 07:46 - 26 Dec 2008 07:47 #254718
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic conversion tables
you can divide your inch lbs by 12 and it will be in ft lbs
1977 KZ650C1
Last edit: 26 Dec 2008 07:47 by mariozappa.
- bill_wilcox100
- Thank you received: 5
26 Dec 2008 07:56 #254720
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic conversion tables
Yes quader98.
As the converter shows you:
1 foot pound = 12 inch pounds
1 foot pound = (1 x 12 inches) 12 inch pounds
Just check if your torque wrench is really in ounce inches! :dry:
In that case you will find that:
1 foot pound = 192 ounce inches
1 foot pound = (12 inches x 16 ounces) 192 ounce inches
Neat converter you found.
Best of success.
Best of success.
Upgrades:
Montreal, Canada
- quader98
26 Dec 2008 08:21 #254722
by quader98
82 GPZ 750 R1
Replied by quader98 on topic conversion tables
cooool,thank you very much
82 GPZ 750 R1
