winter storage
- kawboy13
19 Dec 2008 00:11 #253505
by kawboy13
winter storage was created by kawboy13
For a cold weather climate what storage methods is better the complete draining of tank & carbs or using a fuel stabilizer. here in northern Ohio cold weather the riding days wo'nt be back till April or so. Thanks Kawboy13
- tw..
- Thank you received: 1
19 Dec 2008 05:17 #253520
by tw..
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
Replied by tw.. on topic winter storage
I would fill the tank and add the fuel stabilizer. Run the bike for a bit to get the fuel stabilizer in the carbs and you should be good till April.
2-1976 KZ900 A4
1978 Z1R
- rstnick
- Thank you received: 377
19 Dec 2008 06:08 #253532
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic winter storage
I add stabilzer to a full tank, but drain all 4 carbs.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- RonKZ650
- Thank you received: 240
19 Dec 2008 06:47 #253538
by RonKZ650
Replied by RonKZ650 on topic winter storage
No need to even add stabilizer if you have a full tank. It won't go bad for a year or so. The carbs are a different story. 4 months is pushing it with gas in the carbs. I did the Stabil thing one year on the KZ1000MKII and my carbs were completely clogged whithin a few months so it did no good whatsoever in my case. I drain the gas from the tank and the carbs. Of course the more volume of gas, the longer the time it lasts before going bad. I told my story of my 1993 Ford van that sat 6 yrs without running and it fired right up with 6 yr old gas.
- flht1997
19 Dec 2008 14:35 #253577
by flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Replied by flht1997 on topic winter storage
I used Stabil once, about 15 years ago, all i got in the spring was several racks of plugged carbs, some sort of green gooey crap. now i just drain everything fuel related and have not had a problem.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
- Thank you received: 2829
19 Dec 2008 18:13 #253594
by 650ed
Replied by 650ed on topic winter storage
If you drain the tank you may find condensation will form under certain weather conditions leaving a haze of rust inside. You're better off with a full tank. I also use Stabil, but I don't think it is really necessary. What I do recommend (I do this religiously) is that you start the bike at least every 2 or 3 weeks and let it idle for 15 minutes or so until it is thoroughly warmed up. This prevents the fuel in the carbs from gumming things up, keeps oil on all the internal parts, and keeps the battery healthy. I've been doing this drill on my bike every year (except one) since 1977 with great success. The one year I didn't run the bike I had to remove and thoroughly clean the carbs (oh what fun!). If for some reason you cannot run the bike during the winter, drain the carbs. Ed
