- Thank you received: 14
Turbo 650...
- Bluemeanie
18 Nov 2008 06:42 - 18 Nov 2008 12:09 #248098
by Bluemeanie
Turbo 650... was created by Bluemeanie
I know there are a few "turbo" guys here. You see big block turbos for sale but hardly any small ones such as this
try again... never mind, something is screwed up here! :huh:
Last edit: 18 Nov 2008 12:09 by Bluemeanie.
- steell
19 Nov 2008 05:02 #248286
by steell
Replied by steell on topic Turbo 650...
Yep, something is screwed up here.
Back on the subject, I think a KZR member in Vegas bought a 650 Turbo a while back, don't recall what happened to it though.
- Bluemeanie
19 Nov 2008 06:16 - 19 Nov 2008 06:17 #248297
by Bluemeanie
Replied by Bluemeanie on topic Turbo 650...
Last edit: 19 Nov 2008 06:17 by Bluemeanie.
- Bluemeanie
19 Nov 2008 06:20 - 19 Nov 2008 06:22 #248299
by Bluemeanie
Does Tiny url show up?
tinyurl.com/5aajuy
Woohoo, at least that works! So now you can check out this 650 turbo. Pretty nice bike, would really like to ride it!!
Last edit: 19 Nov 2008 06:22 by Bluemeanie.
- mariozappa
- Thank you received: 8
19 Nov 2008 09:33 #248326
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic Turbo 650...
:S Ummmm, no front brake?
1977 KZ650C1
- H2RICK
- Is this a fun bike, or what!!!
19 Nov 2008 10:53 #248333
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Turbo 650...
Welded crank ??? On a 650 ??? Was it broken in half or something ?? Where DO these a-holes get these ideas !!??!!
Is a potential buyer supposed to assume that it's got a "cool" Z1 "racing" crank in it or something ??
I wouldn't even consider dealing with someone who insulted my intelligence with a statement like that, never mind the rest of his low-rent writeup. Doofus idiot...
- PLUMMEN
- Thank you received: 104
19 Nov 2008 13:09 #248355
by PLUMMEN
Replied by PLUMMEN on topic Turbo 650...
yeah you beat me to the welded crank,maybe he means the nuts are welded on the rod bolts,or the bearings welded themselves right to the crank before they spun!:laugh: looks like an old atp turbo setup;)
- racer54
- Thank you received: 114
19 Nov 2008 18:36 #248399
by racer54
Replied by racer54 on topic Turbo 650...
ATP made a set-up for KZ650's back then. Made a sweet little package then and I am sure now also. Ran like a scolded dog.
- PLUMMEN
19 Nov 2008 19:32 #248415
by PLUMMEN
it might not be so bad i guess if price doesnt go any higher.throw some brakes on the front and a better paint job,although the front brakes might be pretty useless ifthe short little bastard comes on boost ad wheelies in all gears!:laugh:
- RonKZ650
- Thank you received: 240
19 Nov 2008 20:01 #248423
by RonKZ650
Replied by RonKZ650 on topic Turbo 650...
I had the ATP setup on my KZ650 back in 1980. Some odservations I had was the plate that mounts flat across all 4 intakes on mine was warped to impossible to not have vacuum leaks. Fixed that by several hours of hand sanding on a flat surface. After that like all turbos was basically worthless on the street because wouldn't idle smooth ect. Another problem was the KZ650 did not have enough exhaust flow to spin the turbo, so it took several seconds to get any boost at all. After that it ran pretty good, but the stock clutch began to slip, so enough of that for me. Later got the Z1R-TC and it was another real "winner" to say the least. I'll keep the turbo diesels, you guys can have them on gas, never again for me.
- steell
19 Nov 2008 20:41 #248434
by steell
Ron, ever rode a GPZ750 Turbo?? In my opinion Kawasaki got that one right.
- littlemanonbigbike
20 Nov 2008 07:42 #248487
by littlemanonbigbike
1982 1100 Spectre
Various other toys
Replied by littlemanonbigbike on topic Turbo 650...
Did'nt Honda make a small cc turbo bike back in the mid 80's? I worked with a guy back in 87 or 88 that had something like a 500 or 550 cc turbo i wanna say it was a cx or ctx or something like that.
1982 1100 Spectre
Various other toys
