Dyna coil install, GPzInfested method
- steell
23 Aug 2008 13:15 #233606
by steell
Dyna coil install, GPzInfested method was created by steell
GPzInfested decided to install his new Dyna coils on the GPz750 Turbo today, he just ran to get us some food, so I figured I'd sneak a pic and post it.
Serious case of "While I'm there"
- guitargeek
- Thank you received: 50
23 Aug 2008 14:51 - 23 Aug 2008 15:16 #233617
by guitargeek
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Replied by guitargeek on topic Dyna coil install, GPzInfested method
steell wrote:
What all goes on there?GPzInfested decided to install his new Dyna coils on the GPz750 Turbo today, he just ran to get us some food, so I figured I'd sneak a pic and post it.
Yeah, I started my current project intending to just change some gaskets...Serious case of "While I'm there"
Last edit: 23 Aug 2008 15:16 by guitargeek.
- steell
23 Aug 2008 16:17 - 23 Aug 2008 16:19 #233626
by steell
Replied by steell on topic Dyna coil install, GPzInfested method
guitargeek wrote:
It gets pretty crazy here, GPzInfested is my Nephew and we're constantly messing with each other, usually no serious bodily injury though
As far as the shop goes, just our bikes and occasionally a friends bike, get worked on. There are five bikes in there right now, four are ours, and one belongs to the son of a long time friend. Two more are in the storage shed.
"While I'm there" has to be one the most expensive phrases in the English language, next to "I Do"
Yeah, I started my current project intending to just change some gaskets...[/quote]Serious case of "While I'm there"
Last edit: 23 Aug 2008 16:19 by steell.
- guitargeek
23 Aug 2008 18:08 #233640
by guitargeek
No, I meant "what all are you doing to the bike while you're in there?"
- steell
23 Aug 2008 21:29 #233671
by steell
guitargeek wrote:
Me? I'm just trying to keep GPzInfested from going to crazy
He's talking about an 810 kit, GT1548 (I think) turbo, upgrading the injectors, Carrillo rods, Suzuki front and rear suspension and wheels, and a MegaSquirt to allow the extra fuel needed (I think he's envious of Lorcan)
We've already done the compression check, valve clearance check, and discovered a shade tree repair that had been done in the past (that we need to fix). I think we should just put it back together and finish the tune-up so "I" can ride it (it's his bike). God alone knows what the current top speed is, there's no place around here that I can try a top speed run without probably getting myself killed, and he's already pulled the front end up in third gear. So, it seems to me that it is fast enough for right now.
If there was any reasonable possibility of us making it to Bonneville, then I'd be all for it, I'd dearly love to make a 200+ mph run, but I just don't see that happening.
