I need a quick answer please...
- mrapino
10 Jul 2008 16:44 #225408
by mrapino
I need a quick answer please... was created by mrapino
I just bought the Clymer manual for my bike (1982 KZ650H CSR), but most of the information in the manual has to do with the KZ650B, KZ650C, or KZ650D. I was wondering which of these models my bike is most related to.
The manual doesn't seem to mention my bike in particular.
Thanks!
Thanks!
- JohNLA
10 Jul 2008 17:08 #225409
by JohNLA
s49.photobucket.com/albums/f255/JohNLA_photo/1983%20GPZ%20550/
83 GPZ 550 Stock with 3600 miles_83s.
83 GPZ 550 4-1,pods,Mikuni 36,000 + miles
Replied by JohNLA on topic I need a quick answer please...
Does it have a supplement in the back?
- mrapino
10 Jul 2008 17:29 #225410
by mrapino
Replied by mrapino on topic I need a quick answer please...
Yes, it has a supplement, but I am trying to find out about tire pressure, and the supplement doesn't cover that. It only has the one section for tire pressure and it only mentions the KZ650 B, KZ650 C, and KZ650 D.
- Kawiman80
- On my 2nd KZ1000
- Thank you received: 3
10 Jul 2008 18:04 - 10 Jul 2008 18:09 #225414
by Kawiman80
1980 kz1000g 1105 34mm Mikuni flat slides Kerker exhaust custom paint stock ignition(Dyna 2000 soon) Accel coils and wires stock cams w/ heavy springs for more rpm. My 2nd 1000.
Replied by Kawiman80 on topic I need a quick answer please...
does it mention tire sizes for the bikes? If the tire sizes are the same,then the tire pressures should be the same. Assuming you are running a 16" rim with a130/90 series tire,it should be around 35-40psi for the rear and the same for the front. Take into consideration for the tire you are running and look at the side wall to be sure.
Last edit: 10 Jul 2008 18:09 by Kawiman80. Reason: correction
- kawsakiman
- Thank you received: 6
10 Jul 2008 22:07 #225461
by kawsakiman
Replied by kawsakiman on topic I need a quick answer please...
i have a manual for the csr650 i will trade you for the kz one.
shoot a pm if intrested and i'll see if i can dig it up.
in a box somewhere since the move.
btw, factory one or a clymer?
- wiredgeorge
11 Jul 2008 06:26 #225503
by wiredgeorge
Replied by wiredgeorge on topic I need a quick answer please...
Since you are not using the tires originally installed by Kawasaki, I would think the tire pressure spec they provide isn't really relevant. It would be better to look at the sidewall on your tire and see what the tire manufacturer notes as the pressure at max load rating and then back down the pressure a few lbs from the max since you aren't likely riding at max load. In other words, a ME880 has a 50 PSI at 800 lbs. and a Dunlop D404 has a 40 PSI at 750 lbs. it doesn't make much sense to use the SAME spec for both.
- JMKZHI
- Thank you received: 48
11 Jul 2008 07:08 - 04 Dec 2008 07:05 #225524
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 07:05 by JMKZHI.
- Thank you received: 2098
11 Jul 2008 12:47 #225583
by Patton
Replied by Patton on topic I need a quick answer please...
- mrapino
12 Jul 2008 08:47 #225702
by mrapino
Replied by mrapino on topic Thanks everyone!
You've all been a great deal of help. Be sure to look out for pictures of my bike coming soon. It is running, and I just need to do some small stuff to it.
Thanks again.
Thanks again.
- Mark Wing
- Thank you received: 22
12 Jul 2008 21:59 #225803
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic I need a quick answer please...
Your bike is closer to the D than the others.
Yorba Linda Cal.
