Harley/Shadow gas mileage
- steell
16 Jul 2008 05:37 #226451
by steell
Replied by steell on topic Harley/Shadow gas mileage
The fewer cylinders the less frictional and pumping losses, a 700cc single (Panther, the largest I know of) would get much better fuel mileage than a 750cc six cylinder (such as Benelli SEI).
The GPz750 Turbo has a 8:1 or 8.5:1 compression ratio (I forget which at the moment) when it's not on boost, and GPzInfested gets a measured 50 mpg when he really tries, so 60 on a KZ650 sounds reasonable to me. GPzInfested is 5'11 and 250 lbs (he's into power lifting)
seanof30306, you are blowing fuel out the exhaust, get that fixed and your fuel mileage will improve.
My brother gets 40 mpg average out of his KZ1000 CSR pushing a Vetter Windjammer, and he don't care about mileage.
- seanof30306
- Thank you received: 2
16 Jul 2008 05:59 #226466
by seanof30306
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
Replied by seanof30306 on topic Harley/Shadow gas mileage
steell wrote:
Well, at least I'm not blowing smoke out of my a$$
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- tjhiggin
- Thank you received: 1
16 Jul 2008 10:51 #226516
by tjhiggin
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
Replied by tjhiggin on topic Harley/Shadow gas mileage
My good friend Steve has a Victory Vegas with the 100-cubic-inch engine (1638cc) and 6-speed overdrive transmission. He gets about 45 mpg. My KZ1100 gets about 40 mpg.
I rode the Victory for the first time last weekend and was very impressed. In o/d 6th at 80 mph it's running at just under 3000 rpm (redline is 6000 as I recall). The lower rpms, combined with only 2 cylinders, do make for very good economy.
- seanof30306
16 Jul 2008 18:28 #226604
by seanof30306
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
seanof30306 wrote:
Hey, I just re-read this. Want to clarify that I was just making a play on words, not suggesting you were blowing smoke out of your a$$
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- Locozuna
16 Jul 2008 19:18 - 16 Jul 2008 19:19 #226620
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Harley/Shadow gas mileage
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
Last edit: 16 Jul 2008 19:19 by Locozuna.
