Vibration at handle bars
  • jdsmithinc
  • Topic Author
  • You want some of this? Huh? Do ya?
01 Jul 2008 19:11 #223390 by jdsmithinc
Vibration at handle bars was created by jdsmithinc
When I have been riding for a bit the vibration on my Z1 is making my hands numb. Is there anything I can do about this, or do I just need to suck it up?
74 Kawasaki Z1 900
78 Honda CB 750
97 Ford F-150
Mustangs, too many to list on here (I like to rip the pieces of junk apart)
Located in Shelby, N.C.
If life gives you lemons make lemonade, then find someone whos life was given vodka and have a party.
01 Jul 2008 19:17 #223393 by JohNLA
Replied by JohNLA on topic Vibration at handle bars
Make sure you are not supporting your body with your hands. Use your stomach muscles if you have to lean a lot. Keeping a light touch.
Bar end weights might help. Also changing the gearing.
s49.photobucket.com/albums/f255/JohNLA_photo/1983%20GPZ%20550/
83 GPZ 550 Stock with 3600 miles_83s.
83 GPZ 550 4-1,pods,Mikuni 36,000 + miles
01 Jul 2008 20:50 #223419 by Sandy
Replied by Sandy on topic Vibration at handle bars
I've known about this product for a lot of years,but have never tried it...have a look...
www.barsnake.com/
1977 KZ1000 A-1
01 Jul 2008 23:05 #223432 by donthekawguy
Replied by donthekawguy on topic Vibration at handle bars
Some people also use lead shot.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • riverroad
  • 1980 1000LTD B4
02 Jul 2008 03:37 #223445 by riverroad
Replied by riverroad on topic Vibration at handle bars
I read about that barsnake and thought about buying one, but I'm cheap. Tried my own invention. Found a six inch 3/8" pipe nipple, filled it half full with bird shot. pounded a couple egg sinkers in the ends of the pipe to hold the shot inside, then siliconed it into the throttle end of my handle bar.
I borrowed the idea from my dead blo hammer. If you're not familiar with a dead blo hammer, it has loose shot inside it, which absorbs impact and stops it from bouncing like a regular hammer does.
It actually works to some degree.
Right at about 4000 to 5000 rpm, or 60mph or so, I hardly feel any vibration at all and my hand feels fine.
But if I'm running about 80mph, it still vibrates, and my hand goes numb.
02 Jul 2008 09:05 #223494 by 1973Z
Replied by 1973Z on topic Vibration at handle bars
I spent a lot of time on this problem last year and here's what I discovered. Synchronizing your carburetors can make a difference. Otherwise after many unsuccessful experiments I took a box of 50 cal. lead balls for my black powder rifle, slightly flattened them by gently tapping with a hammer, and filled the bar end to end. It's rather heavy but once replaced on the bike it makes no difference and has been fine for over a year. Bar end mirrors also helped. I found early on those bar end weights look cool but had little or no effect on reducing the high frequency buzz. I think the problem may be age related since my bike sat for many years and I don't ever recall the handlebars vibrating when it was new and I rode it a lot of long trips. The lead balls can be removed simply by taking the bar off and holding it straight up and down and letting them fall out. Those sponge rubber looking grips soak up a lot of the vibration as well. A little loctite on the bar end mirror mounting mechanism and I can read the license plates of the cars behind me.
  • Limey
  • 3 Years in the U.K. - Brought the KZ with me!
02 Jul 2008 11:18 #223515 by Limey
Replied by Limey on topic Vibration at handle bars
Do be aware that on some KZs (my 650 is one), some of the wiring is inside the bars, so a device like the Bar Snake will not work.:S
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
02 Jul 2008 13:04 #223531 by KZ250LTD
Replied by KZ250LTD on topic Vibration at handle bars
Just as a warning to anyone thinking of using loctite on plastic in a high vibration spot, I bought a plastic oem fork cover for my 250 the other year and put it in with the right size screws. Lost a few screws before I finally loctited it. Looked at it when I was freshening her up at the start of this season and forcing the piece to bear the vibrations like that cracked it on both sides where the screws go in... oops :blush: :S :laugh:
79 KZ1000ST
Past:
Many.
02 Jul 2008 13:50 #223542 by RonKZ650
Replied by RonKZ650 on topic Vibration at handle bars
Also make sure your motor mount bolts are tight. Loose bolts can cause vibration.
02 Jul 2008 14:07 #223543 by patmann
Replied by patmann on topic Vibration at handle bars
Just wondering how harley riders take all the vibration those things give off:huh: Is everything rubber mounted??
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
02 Jul 2008 14:20 #223545 by Samwell
Replied by Samwell on topic Vibration at handle bars
These guys may help you out: www.manicsalamander.com/
I've used them on my beemer (a flat twin) and it makes a nice difference. It shifts the annoying vibes out of the rev range that I normally use. For example 120km/h is about 3700rpm and the mirrors vibed too much to be useful. With the weights, 3000-6000rpm became clear and smooth (90km/h-160km/h).
They do say they're limited help on in-line fours, but who knows?
Sam
03 Jul 2008 07:24 #223714 by 531blackbanshee
Replied by 531blackbanshee on topic Vibration at handle bars
in the off road world we take and fill the bar end to end with silicone.one tube and the squeeze gun deal a few minutes and your done.don't even have to remove the bars,and it made quite a difference on buzzy two strokers,fwiw.
