1973 float bowl drain plug
- skinner1
23 Jun 2008 13:41 #221713
by skinner1
1973 float bowl drain plug was created by skinner1
Hello,
Recently bought a 1973 Z1. It is missing one of the 17mm float bowl drain plugs in the center of the float bowl. Anybody have one to sell?
Thanks
e-mail is stever@brookledge.com
Thanks
- Thank you received: 2098
23 Jun 2008 14:57 - 23 Jun 2008 15:09 #221730
by Patton
Replied by Patton on topic 1973 float bowl drain plug
Shucks -- thought there was a sure quick answer, as Z1E usually inventories 17mm carb drain plugs (at least for Mikuni 29mm smoothbore carbs), but shows temporarily out of stock. Sorry, I don't know if these will fit the early Z1 bottom-center-drain float bowls.
Depending on the urgency involved, could check with Z1E as to estimated availabilty date, and verify whether these drain plugs listed for Mikuni 29mm Smoothbores with also fit the early Z1 float bowls.
Note this same 17mm plug isn't listed under the 1973 Z1 category.
Z1E 17mm carb drain plug
Good Luck!
Good Luck!
Last edit: 23 Jun 2008 15:09 by Patton.
- wiredgeorge
24 Jun 2008 07:20 #221822
by wiredgeorge
Replied by wiredgeorge on topic 1973 float bowl drain plug
The VM29 drain plug won't fit a 73 VM28SC bowl.
- racer54
- Thank you received: 114
24 Jun 2008 11:31 #221888
by racer54
Replied by racer54 on topic 1973 float bowl drain plug
Just out of curiosity....what is the difference between 29 smoothbores and these 73 Z1 carbs. Sounds like they must look a lot alike. Anyone have any pictures of both to compare. If they do look alike, how do you tell the difference between the two?
24 Jun 2008 13:02 #221903
by Patton
racer54 wrote:
Here's a link to Z1E's carb identification guide.
Click here > Z1E's carb i.d. guide
Good Luck!
Good Luck!
- racer54
24 Jun 2008 13:19 #221907
by racer54
After looking at the pictures, there's no mistaking the smoothbores. Don't think I've ever seen a set of early Z1 carbs before. I was thinking there was a stock set of carbs that looked very similar to the smoothbores and easily mistaken for them. I have to remember all the great stuff Jeff has on his site. Thanks Patton.
- wiredgeorge
25 Jun 2008 07:00 #222045
by wiredgeorge
I believe Mikuni copied the early Honda Keihin CB350/400F carbs as they are remarkably similar... the Honda carbs are smaller and have many poor Keihin design features but they look at lot alike.
