- Thank you received: 14
Figure these out!
- Bluemeanie
22 May 2008 06:16 #215067
by Bluemeanie
Figure these out! was created by Bluemeanie
Ducati has come out with a race replica bike ($72,000!) with a V-4. I've studied this valve train and still don't quite understand how it works, and you thought WE have problems with our 2 valve system? Adjust these...!!
- rstnick
- Thank you received: 377
22 May 2008 06:26 - 22 May 2008 06:28 #215071
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Figure these out!
It's quite simple really.
There's a separate rocker arm to open and close each valve, riding on different cams right beside each other.
In the picture it almost looks like one cam lobe works both rocker arms, but that's not the case. Each rocker has it's own cam lobe.
No springs to close these valves as there are in our engines.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 22 May 2008 06:28 by rstnick.
- N0NB
- Blue handles better
22 May 2008 09:13 #215114
by N0NB
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
Replied by N0NB on topic Figure these out!
Kind of makes under bucket shims seem not so bad.
Nate
- The Milkman
- Thank you received: 194
22 May 2008 15:16 #215169
by The Milkman
Replied by The Milkman on topic Figure these out!
HERE
it is in graphic form on YouTube.
