- Thank you received: 11
I bought another one~Better pics added
- The Gringo
- ¡Usted no necesita otra motocicleta!
22 May 2008 10:15 - 04 Jun 2008 17:44 #215126
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic I bought another one
ltdrider wrote:
Tim don't scare me like that I read 25 and thought I'd lost a few. I just did a quick inventory and I have 4 in the downstairs BR, I just moved the Z-1 Classic from the DR to the LR (doing a little spring re-decorating :laugh: ) there are 3 on the front porch, 3 in the basement plus a titled frame (but that don't count) and in the driveway there are 4 plus a titled roller (that shouldn't count either) plus this one I just bought. That's all the Kawasakis, the Suzuki 550 partsbike is leaning against a tree in the back yard that shouldn't count either. So by my count I only have 16. Dr. Phil, who needs him? Unless of course he has a pocket full of money and is looking for a bike. :laugh: :laugh: :laugh:
Edit: Better Pic added
Andy, if your sig line is up to date, you've got 25 bikes in your stable. Might be time to call Dr. Phil :laugh:
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Last edit: 04 Jun 2008 17:44 by The Gringo.
- ltdrider
- Thank you received: 17
22 May 2008 15:31 #215172
by ltdrider
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Replied by ltdrider on topic I bought another one
Oopps!
I meant to write "15". But I was still off. No one can keep up with you.
Greensboro, NC
- Bad Kaw
- Flying Squirell
- Thank you received: 13
23 May 2008 22:13 - 23 May 2008 22:19 #215472
by Bad Kaw
And it's a 'C' model... :pinch: (que the Charlie Brown "Aaaaaarrrrggghhhh!" sound effect).
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
Replied by Bad Kaw on topic I bought another one
78 Kawasaki Z1R
70 Kawasaki KV75
Last edit: 23 May 2008 22:19 by Bad Kaw.
- The Gringo
23 May 2008 22:42 - 04 Jun 2008 17:46 #215474
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Last edit: 04 Jun 2008 17:46 by The Gringo.
- Bad Kaw
- Flying Squirell
23 May 2008 22:56 #215477
by Bad Kaw
78 Kawasaki Z1R
70 Kawasaki KV75
:blink:
:pinch: :pinch: :pinch:
:woohoo: Aaaaaawwwwwww, I just can't believe it!!!
...nice score!
...nice score!
78 Kawasaki Z1R
70 Kawasaki KV75
- The Gringo
04 Jun 2008 18:14 - 04 Jun 2008 18:16 #217958
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Replied by The Gringo on topic I bought another one ~better pics added
I finally got a chance to get some pics of this bike after doing some minimal cleanup to it. The bike was not quite as nice as I'd hoped it would be but for no more than I had to spend for it I guess I won't complain. The pipes have been drilled by a PO and there looks to be some damage caused by battery acid. I pulled one of the carb bowls and they look to be fairly clean. They will still need to be gone thru but I've seen much worse. I'm going to have to re-do the fuse box because currently it is a plastic cassette case.:S It has a busted turn signal in the front which is no big deal I have those kicking around. The compression seems to be good as does the vinyl on the seat still nice and soft and no tears that I can see. There is a small ding in the tank and I'll need to clean the tank out with acid. The rest of the painted parts are nice. The one thing I'm not too thrilled about is all the white rust/corrosion on the block and cylinders. On the plus side of things it does have a dyna ignition already installed.
My original thought on this bike was to do a full blown restoration on it. Now that I have it I'm not sure that's the way I want to go. Out of sheer laziness on my part I'm considering just slapping the 750 GPZ engine I have sitting around here in it to avoid having to clean up the existing engine. I'm thinking this one may be a long term project. I still need to finish up a few of the other ones I have going.
I've edited earlier posts to add the new pics just start at the top and work down.
closer shot of the engine,
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Last edit: 04 Jun 2008 18:16 by The Gringo.
