Coil Mod in metro detroit
- PFC FNG
- I've got the sickness!!!
18 May 2008 19:53 #214460
by PFC FNG
I know it would not be any fun if it was easy, but does it have to be this much fun?
84 ZX750 GPZ (Waiting for paint)
Eastpoint, Mi
Coil Mod in metro detroit was created by PFC FNG
Is there anyone one in the metro detroit area with some extra time on their hands? I'm looking at doing a coil mod on my 78 KZ650 and figure it would be nice to have some extra knowledge to rely on.
Eastpoint, Mi
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
18 May 2008 20:45 #214473
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Coil Mod in metro detroit
PFC FNG, this is NOT rocket science. I did mine in about an hour and a half....and the longest part of that time was deciding where to put the relay and then mounting it there.
The rest of the process was pretty simple...mostly soldering and heatshrinking.
BTW, I mounted my relay up inside the frame behind where the horn mounts on the stock bike. When the tank is on you can't even see the relay and the wiring.
Startups are now instantaneous because you're getting pretty much full battery voltage at the coils so you get full coil saturation quickly....and NO coil overheating/cracking due to low primary voltage/high amperage conditions. What's not to like ???
