Any backyard mechanics in the Ottawa Ont area?
- Kevin65
05 May 2008 11:14 #211347
by Kevin65
Any backyard mechanics in the Ottawa Ont area? was created by Kevin65
I am starting to get fed up with my 1984 KZ550 LTD. I have been fighting to get it to run properly for two years and I am at the point where I need someone new to look at it. It runs rough, and switches around on the cylinders it is running on. It also needs the front brake bled. I spent hours and cannot get full pressure. The motorcycle dealers have no interest in working on old bikes, unless somebody knows of one around Ottawa.
Thanks
Kevin
Thanks
Kevin
- JohNLA
05 May 2008 13:17 #211395
by JohNLA
s49.photobucket.com/albums/f255/JohNLA_photo/1983%20GPZ%20550/
83 GPZ 550 Stock with 3600 miles_83s.
83 GPZ 550 4-1,pods,Mikuni 36,000 + miles
Replied by JohNLA on topic Any backyard mechanics in the Ottawa Ont area?
Have the valve clearances been checked?
Carbs synced?
You can try wrapping a bungee chord or something similar around the brake to keep it real tight. Let it set over night and it should allow the last bit of air to escape and leave you with good brakes.
Carbs synced?
- Kevin65
05 May 2008 15:17 #211408
by Kevin65
Replied by Kevin65 on topic Any backyard mechanics in the Ottawa Ont area?
The valves were done prior to the prvious owner - my father in law - storing the bike for a couple of years. The brake has pressure, but it pulls in all the way to the handlebar, I will try the bungee trick tonight. The carbs were gummed up and I put rebuild kits in them and blew compressed air through all the passages, but they cut in and out. I have had them on and off 15 or 20 times - I'm pretty quick doing that now. Perhaps a new set might be in order, although if I buy used I could be dealing with the same problems.
- Kevin65
05 May 2008 15:30 #211409
by Kevin65
BTW - you guys always ask for photos - here they are.
- Kevin65
05 May 2008 15:32 #211410
by Kevin65
oops - too big
- Kevin65
05 May 2008 17:52 #211434
by Kevin65
Success! I cleaned the carbs last weekend and installed them tonight. All four cylinders are firing. I have a bungee cord around the brake and we will see if that helps.
Thanks for the advice - and motivation.
- dkmk
- Thank you received: 18
06 May 2008 19:54 #211690
by dkmk
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
Replied by dkmk on topic Any backyard mechanics in the Ottawa Ont area?
Kevin, you could try to contact Steve Darlington (username darlington). I believe he is in your area. He might be busy as he races in the
VRRA
, but he might be able to point you in the right direction.
Northern Ontario
