need opinions
- rdgrnr
need opinions
04 Apr 2008 20:16 - 04 Apr 2008 20:17
Hi,
I have the cams for my 1000 for sale on ebay along with the bearings and caps. I just received a message stating the following:
"Sir, this is not a question but rather a request. Please do not sell the bearing caps with the cam shafts. The bearing caps were machined at the factory to the head and must must must be sold with the engine head. Just a friendly heads-up! Good luck with your sales."
Is this true?
Is this true?
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
Last edit: 04 Apr 2008 20:17 by rdgrnr.
- N0NB
- Blue handles better
Re: need opinions
04 Apr 2008 20:38
Yes.
For the 650, at least, the caps are numbered and the manual states that they should not be installed in any other position since the machining process is done with them in place and they align as a true bore in that position.
He's right, keep them with the head.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- rdgrnr
Re: need opinions
04 Apr 2008 20:43
Thanks, I'll fix my listing.
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- PLUMMEN
Re: need opinions
04 Apr 2008 21:40
yeeeeeeeeeee-ep;)
- jonnybiker
Re: need opinions
05 Apr 2008 00:33
Ok, what cams , how much you looking for , and can you give me a link or auction number?? thanks much. jonnybiker
- rdgrnr
Re: need opinions
05 Apr 2008 07:29
They are for a 79 1000. I'm not good at links, but here is the Item number: 260226311136
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- rdgrnr
Re: need opinions
05 Apr 2008 10:00
need more advice please..
I am also selling the head. It is in good shape, no broken fins. Do I sell it with the shims and buckets, or sell them separately? How much should I ask for the head with and without the shims and buckets?
Thanks
Thanks
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- racer54
Re: need opinions
05 Apr 2008 12:54
Sell the head with the buckets/shims if it's to one of us guys here. LOL Usually,the head is sold seperately with the cam caps. Shims/buckets are sold seperate and alone...I've seen it both ways. Most guys will probably be looking at the shims anyway. Personally, I don't look at buckets much but always look at shims for the sizes..list the sizes.
- rdgrnr
Re: need opinions
05 Apr 2008 13:04
It is to one of the guys here, and I have no idea what the sizes are. Are they measured in diameter or thickness?
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- N0NB
Re: need opinions
05 Apr 2008 19:36
Thickness in fractional millimeters.
Nate
- rdgrnr
Re: need opinions
05 Apr 2008 21:18
ok, got it..Thanks. I don't know if me eyes can see in fractional millimeters:laugh:
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- N0NB
Re: need opinions
06 Apr 2008 05:18
You'll see them marked as 270, 265, 260, 255, 250, etc. If you mic them, they are 2.650 mm, 2.500 mm, 2.450 mm, etc.
There are different diameters as I recall (somebody will correct me if I'm wrong) so order for your engine and you'll be fine. So far I've ordered my shims through Z1 Enterprises. Often a few shims can be shuffled around and then just the ones needed have to be ordered.
Nate
