Help me guys, I need a few items
- ten6
11 Mar 2008 22:05
Hey guys...I'm trying to get a few 77-79 KZ650 projects off the ground (actually, back ON the ground). I need a baffle for a Kerker or similar exhaust measuring 3 7/8" diameter. I am also in need of the proper tool or bolt to remove the rotor for the alternator. Can you help me? Drop me a line. Thanks.
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
- steell
Re: Help me guys, I need a few items
12 Mar 2008 08:20
I use a rear axle to take the rotor off, think it was the 650 axle, it's the same size as the 750 rotors including the GPZ. You may be able to use the steering stem bolt (the chrome one), heard it works but I haven't tried it.
Can't help you with the baffle though, I have three mufflers and none have a baffle
12 Mar 2008 09:31 - 12 Mar 2008 09:33
ten6 wrote:
To see the $44.95 Kerker baffle made by Mac, open this link, click on Exhaust Parts (left side of screen), then click on Baffles. Scroll down to the $44.95 Kerker baffle made by Mac.
supplier
Good Luck with the quest!
... need a baffle for a Kerker or similar exhaust measuring 3 7/8" diameter....
supplier
Last edit: 12 Mar 2008 09:33 by Patton.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
12 Mar 2008 10:35
steell wrote:
Does anyone know if this same axle bolt trick can be done with the KZ1000 (J engine)?
I've never taken off a rotor, but I may have to do it. Can someone please explain how you do this with the axle bolt?
Thanks.
Thanks.
West Linn, OR
- steell
12 Mar 2008 12:32 - 12 Mar 2008 12:33
It works on all the other KZ's, either the rear axle or the steering stem bolt (or both), so it should work on the J motor.
Take out the bolt that holds the rotor on, screw in the axle or steering stem bolt (preferably the axle), make sure it's as tight as possible, smack the end of the bolt with a large hammer (and I don't mean a love tap, give it a good hard smack), and it should pop right off. If it don't then tighten the bolt/axle and do it again.
Do not under any circumstances hit the rotor with a hammer.
Haven't tried it on the J, but it works that way on the others.
Last edit: 12 Mar 2008 12:33 by steell.
- Skyman
12 Mar 2008 15:46 - 13 Mar 2008 14:46
steell wrote:
Thanks, Steell. I'll give that a try if it turns out I need to get the rotor off. As I posted in my "Loud Clunk" thread, I'm having issues with my starting system "skipping" while cranking. This started happening after I installed the 1135 10.25 kit on the bike. The starter cranks REAL SLOW and then sounds like it skips gears. Battery is new and fully charged. Starter gear looks good. Someone suggested maybe the stock starter doesn't have enough torque to crank the new pistons, and perhaps that is cauing the starter clutch to not engage fully.
So I ordered a Honda CB900f starter from Ebay and am waiting for it to come. I've read this is a common bolt-on fix for big bore converts with starter problems. So I'll try that first to see if that solves the skipping problem. If not, next step is to pull the rotor and take a look at the starter clutch condition.
Thanks for the axle bolt tip.
West Linn, OR
Last edit: 13 Mar 2008 14:46 by Skyman.
- Kawickrice
12 Mar 2008 18:51
I had that clunk in a z1 motor and traced it to the altenator rotor bolt. the bolt would back out and the rotor would slap the stator. Charging system died as it took out the stator, the starter would also do what you described as the starter gear got loose with the rotor. The steering bolt worked like a charm. A little loctite and a new stator and the clunk went away.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
