just aquired : 81 KZ1000
  • Kingcobra
  • Kingcobra's Avatar Topic Author
22 Feb 2008 20:03
#196394
just got this bike tonight (will get pics tomorrow) and all I'm using off it is the engine and I was looking for any opinions or experience with this engine. for some reason the spark plug holes are too large for B8es plugs to screw into... so it has some kind of adapters screwed onto the plugs... any ideas about this? surely it's not stock right?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: just aquired : 81 KZ1000
23 Feb 2008 02:00
#196410
No, not stock. Sounds like (without seeing, of course) the plug holes have been drilled/tapped and/or helicoiled. You may have to redo them, or go to an alternate system...or replace the head. Pictures will tell.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • brumbear
  • brumbear's Avatar
23 Feb 2008 05:22
#196411
The Engine may have to be rebuilt if someone helicoiled the plugs the probabilty of chips dropping into the cyl. is high. I know if you grease the flutes of the tap and go slow no problems but I am figuring if whoever was able to strip 4 plugs well you can guess the rest
  • Kingcobra
23 Feb 2008 13:42
#196493
yep.... looks like I'll need a head for it.
anyway here it is.
  • Kingcobra
23 Feb 2008 19:09
#196540
so... I'm thinking I want these DID wheels and all the brakes on my 78 KZ650 B... what are the chances of the front and rear axles being the same diameter on both bikes?
