KZ 1300
  • roy-b-boy-b
  • roy-b-boy-b's Avatar Topic Author
Re: KZ 1300
22 Feb 2008 14:40
#196324
That is some serious modifications!:blink:
Thanks everyone for the info. Roy
  • N0NB
  • N0NB's Avatar
  • Blue handles better
Re: KZ 1300
22 Feb 2008 14:49
#196325
The latest issue of Motorcycle Classic features a story on the KZ1300. The example in the pics is beautiful and owned by a guy in British Columbia.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: KZ 1300
22 Feb 2008 15:15
#196332
Otakar,
My 81's ready to ride. My 85's just about to get off the stand. I've finished cleaning the injectors. Hopefully they'll hold pressure this time. If they do I just need to swap the clutch to a KZ clutch from a ZN clutch and I should be on the road.
kzcsi
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • jjdwoodman
  • jjdwoodman's Avatar
  • Live free, or die.
Re: KZ 1300
22 Feb 2008 17:07
#196351
Hi Otakar. I'm still in the dreaming stage on my 1300 basket case, though the Voyager is seeing plenty of use. If you don't mind, are you planning any mods for the cooling system? And where do you stand on the 1500 liners?
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • otakar
  • otakar's Avatar
Re: KZ 1300
22 Feb 2008 19:22
#196383
The liners cost me $1400 just to have them made. Than the hard part starts. This is machining the cylinder block to take them. There are two distinct diameters and than the "O" ring grooves. I have a bad feeling that it will run hot. This is why I have 6 sets of cylinders. If I don't like one I'll just swap them. I have much more confidence in the 1400 kit. Wiseco made custom pistons for me and it was much cheaper for the entire project. Where the total price for the cylinders on the 1500 kit cost me about $2700 for everything (I did all the machining myself except for making the inserts) the 1400 cost me only $1400 for everything. The head is about $1000 with the new parts and the cams were $700. Needless to say I have a bit of coin in this bike just in the motor alone.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • jjdwoodman
Re: KZ 1300
22 Feb 2008 19:33
#196386
So what about the 650 pistons idea? Will the skirts be too thin after boring? Or did you go with aftermarket pistons for a little more compression. I had thought about trying to cast my own dome head pistons to up the compression without oversizing the bore and going with a weld/regrind cam job and porting maybe oversize the valves for better breathing. Seems like the head work is the safer way to make ponies...?
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • jjdwoodman
Re: KZ 1300
22 Feb 2008 19:41
#196388
No, I'm losing my mind. Already has the dome pistons, I was going to try flat pistons to drop the compression for use with a turbo.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • otakar
  • otakar's Avatar
Re: KZ 1300
22 Feb 2008 19:43
#196389
The 1400 has custom Wiseco 11:1 pistons which were cut to my specs, and the 1500 has GPz750 pistons. In both cases the lower sleeve is .06" thick.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
