- Thank you received: 19
Tiny tank leak/sealer?
- KZ_Rage
- Kentucky Bourbon Barrel Ale
28 Jan 2008 17:18 #191501
by KZ_Rage
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
Tiny tank leak/sealer? was created by KZ_Rage
Well I've had another setback with my tank after the first issue of the petcock leaking around the handle like crazy, so I got a Pingel from Z1 and that problem is fixed.
The new problem, I decide to fill the tank all the way up so help prevent rust. Just as I topped the tank off, I see gas dripping off the back end of the tank pretty damn fast. The rear tang that the seat makes contact with is leaking around the spot welds from what I can tell. Makes about 3 drips a second. It appears that when I had the tank dipped it must have removed either a bit of rust on the inside on the spot weld or there was some kind of sealer on it that it dissolved away in the dip.
Any suggestions on how to seal this other than grinding the tang off and soldering a patch plate over the hole?
I really don't know what that tang is there for exactly. I assume it is to keep the tank on the bike in case of a drop as the seat has it held down. The thing is though that there is another tang on the rear of the tank that snaps into a rubber grommet on the frame and the seat is angled over top of the rear of the tank anyway so it would take a lot of force to knock it out from under the seat. I'll probably leave the tang off unless I can see or hear another reason for it other than as a retainer.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
- KZQ
- Administrator
- Thank you received: 1406
28 Jan 2008 19:52 #191548
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic Tiny tank leak/sealer?
Is it somewhere where it can be soldered or brazed?
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- free B
28 Jan 2008 19:56 #191550
by free B
Replied by free B on topic Tiny tank leak/sealer?
Por 15 works great.
- KZ_Rage
29 Jan 2008 06:26 #191595
by KZ_Rage
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
Replied by KZ_Rage on topic Tiny tank leak/sealer?
Here is a photo of another tank I had in my photo file that I marked up so you could see where it is leaking.
I thought about POR15, if I don't coat the whole tank with it but just the back end will it work or does it fail if there is an "edge" to it?
Post edited by: KZ_Rage, at: 2008/01/29 09:38
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
- kano
- Not Another Bloody Limey!
29 Jan 2008 06:41 #191598
by kano
Replied by kano on topic Tiny tank leak/sealer?
I used kbs coatings their ebay store is here:
link
i had a tank fail and after talking to them they recommended against using a carbon cleaning additive in the fuel and sent me a new kit free even though it was kind of my fault.
i did have pin holes in my tank which i brazed over first instead of relying on the sealer alone.
- Thank you received: 2098
29 Jan 2008 07:19 #191605
by Patton
Replied by Patton on topic Tiny tank leak/sealer?
Might also consider West System two part epoxy to coat and seal inside of tank. Here is the website for further info.
www.westsystem.com/
www.westsystem.com/
- Grantl
- KZRider is Da Bomb!!!
- Thank you received: 4
29 Jan 2008 10:17 #191650
by Grantl
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
Replied by Grantl on topic Tiny tank leak/sealer?
KZ Rage,
I recently had a similar problem with a leak in my tank. Below is the thread that explains how I fixed the problem.
Grant.
kzrider.com/component/option,com_joomlab...w/catid,5/id,164906/
Grant.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
