motorcycle tire changing
  • Scrapper
  • Scrapper's Avatar Topic Author
  • I Survived P.D. Fri .the 13th 2008 .
16 Jan 2008 15:34
#189615
Want to build your own work station for tire repair and Wheel balancing?
Here ya go!
www.clarity.net/~adam/tire-changing-doc.html#2
Cheers ..ScrapperB)
Handle every situation like a dog,
If you can't eat it or hump it,
Piss on it and walk away!
Re: motorcycle tire changing
16 Jan 2008 18:47
#189644
Not bad, but I don't buy onto the way he balances his wheel/tire. He finds the heavy spot (that's good) and then adds sufficient weight 180 degrees away from it to balance it (that's bad.) This leaves him with the classic "barbell" effect. That is, 2 heavy spots opposite each other. You'll notice nobody makes cast wheels with only 2 spokes, but there are numerous wheel manufacturers for bikes and cars that make 3 spoke cast wheels. This eliminates the barbell effect by evenly spreading the heavy spots around the wheel. I achieve this effect when balancing wheels by marking the heavy spot then measuring 1/3 the distance around the wheel from it in each direction and marking these 2 spots. I then add equal amounts of weight to these 2 spots until the wheel no longer stops at any particular spot after giving it several spins. This has always produced good results for me. Ed
  • JMKZHI
  • JMKZHI's Avatar
Re: .
16 Jan 2008 20:16 - 03 Dec 2008 20:31
#189657
del
Last edit: 03 Dec 2008 20:31 by JMKZHI.
  • BSKZ650
  • BSKZ650's Avatar
17 Jan 2008 05:06
#189686
I decided years ago, pay the man to change the tire and balance it
77 ltd1000, current rider
76 kz900, just waiting
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
17 Jan 2008 05:12
#189688
Interesting, I'll rebuild motors, front ends, etc, but when it comes to tires...same as BSKZ650, I take it to someone also:laugh: :laugh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • otakar
  • otakar's Avatar
17 Jan 2008 06:43
#189694
I have also been taking my wheels in to have them done. The problem is that I have done 8 wheels in the last two years and that is over $350. I just bought all the machines to do the job at Harbor Freight Tools. Everything I neaded to change and balance Bike tires cost me about $125. This is paid for in about 2-3 tire changes.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • BSKZ650
  • BSKZ650's Avatar
17 Jan 2008 07:16
#189699
Looking at the list of bikes you have, I can see it might pay to own your own equipment,too bad you live too far or I would pay you to change mine also
  • Bluemeanie
  • Bluemeanie's Avatar
17 Jan 2008 07:24
#189701
Same here, have done a couple and it's tough. I just have the place I buy the tire at change it. It's usually free with tire purchase. Plus, last time they installed new tire they popped tube so I got brand new one free!
Post edited by: Bluemeanie, at: 2008/01/17 10:25
17 Jan 2008 11:35
#189747
Being an expert tube pincher, I get new mail order tires mounted and balanced at the local Kaw dealer for $25 each wheel, and consider it money well spent. The price includes removal and disposal of the old tire. Dealer adds a small charge for any weights needed.
This is the price where I have already removed and deliver only the wheel (old tire still mounted) to the dealer. Am guessing it would be more expensive for the dealer to also remove and replace the wheel.
Don't mind at all removing and replacing wheels, but would rather than change tires. :lol:
17 Jan 2008 12:29
#189757
Sounds like this could be a very wise (and almost enjoyable) investment. :cheer:
Would these tools include the $30 portable tire changer, plus $50 motorcycle tire attachment, and possibly the $50 portable wheel balancer (bubble style) or other type balancer?
Hope these tools perform as advertised and that you'll please give us a performance report when able. :)
  • wiredgeorge
  • wiredgeorge's Avatar
18 Jan 2008 07:11
#189896
otakar, I have one of the HF tire changing machines with the motorcycle adapter. If you change a 19" rim, it works OK.... I have to use tiedown straps to keep the tire/rim in place because the holders don't work all that well in clamping a rim. The bead breaker works fine and the long bar they give you is good for pulling the bead off the rim but you will also need a couple good tire irons... the Motion Pro long curved spoon type work well... they are a MUST. The machine doesn't work as well on smaller rims... like 15" bike rims. The sidewalls of the smaller and wider tires are STIFF and much tougher to get on/off the rims. Last, seating the bead on the rim is often a chore. I think Motion Pro sells both a strap type tool and an inflatable tool that you wrap around the tire and tighten to force the bead to the rim and of course this requires a compressor to inflate... a little DC compressor won't seat a bead. It generally takes me half a day or sweaty work to change two tires and balance them (I have a balance machine as well) so I usually take them to a shop that does this stuff for me at $25 a set... they have a hydraulic machine and tire changes are a lot quicker... an hour in and out.
