need suggestions
  • quader98
  • quader98's Avatar Topic Author
need suggestions
26 Dec 2007 17:31
#186482
I've been working on my bike on my off time.i have the rest of the year off and i have to use my time smart.in my attempts to find an electrical problem i pulled the plugs and noticed that they were a little silverish,the po told me it was jetted...oh well.i pulled the tank off ,just to make things easier to check, cause i wanted to check compression and maybe the valve clearances tomorrow.i dont know what to check first,i need help,should i check the carbs first or the compression or the valves or should i be checking something else instead... i don't know,can you dudes please give me some input...thanks
Post edited by: quader98, at: 2007/12/26 20:34
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
  • kawsakiman
  • kawsakiman's Avatar
Re: need suggestions
26 Dec 2007 17:54
#186485
compression
valves
then carbs
  • steell
  • steell's Avatar
26 Dec 2007 18:43
#186490
With silver plugs the first thing I'd do is shine a light through the spark plug hole and look at the top of the piston(s). Silver plugs are generally caused by detonation, and that's not good.
Have you ever heard this bike run?
I'd do a compression check to make sure you don't have a holed piston, if the compression is there, then I'd adjust the valves and recheck the compression.
If everything else is good, then mess with the carbs.
  • quader98
26 Dec 2007 18:52
#186491
oh yea it runs,pull the choke starts right up...warmed up push in choke and it will idle no problem.the only reason i checked the plug is cause at 4000 she poped a little,not loud
82 GPZ 750 R1
  • quader98
27 Dec 2007 14:27
#186593
thanks for the help gonna post in the appropriate forums
82 GPZ 750 R1
