- Thank you received: 5
Another confused seller on Ebay
- z1rick
21 Dec 2007 20:25 #186013
by z1rick
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
Another confused seller on Ebay was created by z1rick
These rotors came off a '74 Z1 900? Gee, my 900 has a 4 bolt pattern, not 6...
tinyurl.com/26pyxr
I just post these examples to warn buyers, read the auction add carefully and look closely at the Pics before you buy.
tinyurl.com/26pyxr
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
- Shoe48
- Live each day as it is your last
21 Dec 2007 20:36 #186016
by Shoe48
Replied by Shoe48 on topic Another confused seller on Ebay
I thought 6 holes was Suzuki ?
- bob_z1
- Thank you received: 1
21 Dec 2007 22:41 #186020
by bob_z1
Replied by bob_z1 on topic Another confused seller on Ebay
look right to me.... 73 to 73 Z1-900 take 6 bolt, 76 KZ900 and 77-80 KZ1000 take 4 bolt front rotors.
- early73z
22 Dec 2007 00:07 #186022
by early73z
Replied by early73z on topic Another confused seller on Ebay
I agree with bob_z1, my 74 Z1 rotor is held on with 6 bolts and my factory manual shows that the 73-75 Z1 rotors changed to a 4 bolt pattern for the 96 KZ.
If your 900 has a 4 bolt pattern rotor, then it isn't from a 74. Probably has a 96 or later wheel and rotor.
- roy-b-boy-b
- Thank you received: 103
22 Dec 2007 05:43 #186028
by roy-b-boy-b
Replied by roy-b-boy-b on topic Another confused seller on Ebay
Those rotors are heavy! Roy
- Bluemeanie
- Thank you received: 14
22 Dec 2007 06:34 #186035
by Bluemeanie
Replied by Bluemeanie on topic Another confused seller on Ebay
I know what you mean Rick, I could post these things all day. I see goofs everywhere on ebay. Buyer beware!!
- Jeff.Saunders
22 Dec 2007 06:37 #186036
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Another confused seller on Ebay
The 6-bolt pattern IS CORRECT for the Z1. The 4-bolt pattern is on the KZ900 and KZ1000 models.
Z1 Ent on Facebook,
- arai59
- Banned
22 Dec 2007 06:51 #186037
by arai59
Replied by arai59 on topic Another confused seller on Ebay
yup.......75z1 has 6 as well.
- kawtoy
- Thank you received: 6
22 Dec 2007 06:52 #186038
by kawtoy
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
Replied by kawtoy on topic Another confused seller on Ebay
Hey Rick, make sure you check you bike over carefully before you buy any more parts. You might have other parts that are not correct. It would suck to order aprts that do not fit because someone switched stuff on the bike without you knowing it.
- arai59
- Banned
22 Dec 2007 11:28 #186068
by arai59
Shaft bikes had 6 bolt also I believe.
Post edited by: arai60, at: 2007/12/22 14:28
- z1rick
22 Dec 2007 19:52 #186107
by z1rick
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
Replied by z1rick on topic Another confused seller on Ebay
I guess that is what you call a brain f**t:P
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
- early73z
22 Dec 2007 22:03 #186112
by early73z
It could happen to anyone. :laugh:
Many years ago I put a correct for the Z1, Lester rear mag on my 74 . Went looking for a matching front Lester for about 18 months and finally found a "used" but never mounted front, at a nice price. Got it home to find it was for a 4-bolt 96 KZ900. Instead of returning it, I figured I'd swap out all the front end hardware necessary to use the 96 mag, as well as adding a second rotor kit when I did the swap. Never got around to doing the swap, so the mag is sitting in the garage somewhere. If I had been a more industrious person and then eventually sold the 74, it's possible that the new owner would have been convinced the 74Z1 had 4 bolt rotors on front.
z1rick, I see that you have a 74 project. I hope to get into a restoration of my old 74 starting this coming spring. I'll be interested in your progress.
Post edited by: early73z, at: 2007/12/23 01:05
