1000 engine in a 750 frame?
- lunchbox
18 Dec 2007 15:10
ok so i'm still looking for an engine and i was just browsing when i saw a nice kz1000 engine. just what kinda mods would i have to do to my 750 frame? i wanna know if it's worth the hassle, because i can't find any 750 engines cheap enough and this has a pretty good price on it
- Bluemeanie
Re: 1000 engine in a 750 frame?
18 Dec 2007 15:44
You'll have to gusset the frame to handle the extra power and will have to make you own motor mounts, but with skill it can be done. Below is a 1000 in a 650 frame!
- lunchbox
18 Dec 2007 15:50
that is just beautiful! i was thinkin i'd have to cut up the frame and re-weld some stuff, but that doesn't look too bad, now i just need to find someone with some tools to use since i lost most of my stuff in the divorce
- steell
18 Dec 2007 16:15
Make new motor mounts to set the motor as low in the frame as possible, that way you won't have to modify the fuel tank for clearance.
- Spot
13 Jan 2008 18:42
Is that an oil cooler just beneath the triple tree?
Good judgment comes from experience, which usually comes from bad judgment. - Will Rogers
- rstnick
14 Jan 2008 06:20
Looks like one.
A GPz750 Oil pan and cooler will bolt right onto a 650.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- themachine
14 Jan 2008 12:06
and make sure you use bolts on the three lowest clutch cover holes, otherwise you'll have to unbolt/lift the engine to get at the allen heads.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- CruisingRam
14 Jan 2008 22:12
You know, you will have to do a search, I hope the pics are still hosted there, but in the archives, there was a guy that put a GPZ 1100 motor in a 750 frame, and had it so that he could still remove the valve covers.
Also had USD forks and kick ass rims. It was about 90% finished in the last pic he posted, and I didn't hear about him again, even though I think I posted a couple of posts on the thread.
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
- gorack
15 Jan 2008 00:02
that is a 1000\900 frame in that pic just look at the rear foot peg mounts but a 1000 motor can be put into a 650 frame just needs some modificationsB)
- OnkelB
15 Jan 2008 03:13
CruisingRam wrote:
That was messenger1, one of the sweetest builds ever - pics are still there though I haven´t seen him around in a good while:
kzrider.com/archive/viewthread.php?tid=14814#pid224166
kzrider.com/archive/viewthread.php?tid=26143#pid223990
77 KZ 650 B1, 82 GPz 1100 B2.
- StreetfighterKz
15 Jan 2008 04:51
gorack wrote:
Pretty sure its a 650 frame. There are no stud holes by the swingarm pivot bolt for the standard foot peg mounts like the 900/1000 and the rear foot peg mounts are closer and higher to the frame than a Z1 or 900LTD.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- OnkelB
15 Jan 2008 07:19
gorack wrote:
It´s a 650 frame alright, the bike used to belong to KZR member Zman, if I remember correctly he put it up for sale a while ago. Here are a couple of links where he mentions modifying the rear peg mounts ao - unfortunately his pics are no longer there.
kzrider.com/archive/viewthread.php?tid=3911#pid23356
kzrider.com/archive/viewthread.php?tid=3976#pid23891
