Stainless braided brake hose
  • Bluemeanie
  • Bluemeanie's Avatar Topic Author
15 Dec 2007 15:55
#185214
Don't know if anyone noticed but Z1 now stocks stainless braided brake lines and fittings! You can get all the lengths and angles. We've discussed where to get these parts, will have to see if price is right. Z1 has always been pretty good with prices though...
Z1 brake lines
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: Stainless braided brake hose
15 Dec 2007 16:09
#185215
oh...my...god...
:blink:
Finished lines (with ends), sized to the inch (in length), very reasonable prices...
I'm not doing it the old way anymore...
B)
EDIT: I just figured it out... I did it myself last time, with components from "Earl's", and I crimped it all up myself. Now, the same or similar components from z1Enterprises.com would have saved me $16.46, and I wouldn't have to do it myself... and what I mean by "doing it myself" really comes down to the hack-sawing of the lines, poking my finger with the sharp braiding, and bleeding all over the place.... ;)
Post edited by: Biquetoast, at: 2007/12/15 19:38
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • The Milkman
  • The Milkman's Avatar
15 Dec 2007 17:02
#185224
Well, that solves one of my projects for this winter,,, WOO, HOO :woohoo: :woohoo:
  • RonKZ650
  • RonKZ650's Avatar
15 Dec 2007 17:11
#185226
Looks good. I've never seen hoses that the banjo fittings were not an integral part of before. Normally you buy a hose with the banjos built right in. Whether this system is better is hard to say. Probably work fine either way.
  • z1rick
  • z1rick's Avatar
15 Dec 2007 18:05
#185233
Thanks John, the braided SS lines would look sharp on my Cop bike:P
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
  • Biquetoast
15 Dec 2007 18:16
#185237
RonKZ650 wrote:
...I've never seen hoses that the banjo fittings were not an integral part of before. Normally you buy a hose with the banjos built right in...
Actually, this is one (of the many) reasons I wanted to build them myself last time. Having the ability to set the exact direction of the hose without trying to twist it is important. The lines really don't twist. And if the built-in banjoes aren't lines up exactly right, your host can get a crazy curve or bend to it, or not tighten at all.
You need at least *one* side with a rotating connector, I find. And in this case, both sides are, making just as easy....
kz750twins.com
