Small dent in the tank: Repair it? Replace it? Or just live with it?
  • ZappBranigan
  • ZappBranigan's Avatar Topic Author
13 Dec 2007 13:58
#184922
Okay, so my old Spectre has a nickel-sized dent on the left side of the tank. Nothing serious, and it's not all that noticeable (except to me.)
Just wondering if I should make an effort to try and fix it (I've heard about some kind of fix that involves dry ice?), buy a replacement tank (how common and/or expensive can a replacement tank be? The Bike Bandit price is something like $700 which is almost what I paid for the bike so Obviously I'm not going to do that), or just live with it? Currently my inclination is towards the latter, but if I'm going to try and repaint the bike, it would seem to be a waste of time to repaint the tank if it still has the dent in it - might be better off just getting a new tank and painting that one to match.
You can see the dent in this photo (just below my "ghetto" brake fluid reservoir clamp! :P )
"When I'm in command, Every mission is a suicide mission!" - Zapp Branigan
82 KZ750N1 (Spectre)
24k Miles
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Small dent in the tank: Repair it? Replace it? Or just live with it?
13 Dec 2007 14:17
#184925
I bet that will come out with dry ice. Some one recently posted a YouTube video of the dry ice method, see if you can find it.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • jonnybiker
  • jonnybiker's Avatar
13 Dec 2007 14:17
#184926
You ride around with a c-clamp clamped on your brake master cylinder...... , but your that bothered by a nickle sized dent in the tank? my advice....repair replace the master cylinder problem and live with the dent till you repaint. then a smear of body filler and a bit of sanding and your good to go. jonnybiker
  • BSKZ650
  • BSKZ650's Avatar
13 Dec 2007 14:27
#184928
I would wait until you are ready to paint the bike then remove the dent.
with the dry ice there is always a chance of the paint cracking and then it will look way ugly
77 ltd1000, current rider
76 kz900, just waiting
  • Bluemeanie
  • Bluemeanie's Avatar
13 Dec 2007 14:34
#184929
Zapp, here is the video I posted awhile back. It's on automotive metal, your tank is thicker metal so may take a little longer. I've never tried it so do so at your own risk. :)
tinyurl.com/2prb5f
Post edited by: Bluemeanie, at: 2007/12/13 17:36
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
13 Dec 2007 15:23
#184939
I tried to dry ice my tank last night. My tank has a variety of dents from a LARGE crease all the way to very small dings... the dry ice did nothing to any of them. I left a large block of dry ice on one of the very small dents for over a half hour, and got no reaction.
It could be because it is cold here right now (in the middle of a wonderful NY winter). however i did heat the area before hand with a blow drier (I say that mentioned in one dry ice dent removal walk through).
THe dry ice did however make my beer nince and cold, so it was not a total waste.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • KZErider
  • KZErider's Avatar
13 Dec 2007 16:03
#184943
I've always heard that it works best on a real hot day after leaving the car/truck/bike(?) out in the sun for a while. Guess that's no help for up North right now.
Never tried it myself -- just what I've been told.:)
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
  • limitfish
  • limitfish's Avatar
13 Dec 2007 19:12
#184963
There is a guy around here that removes dents with a system of different sized and shaped "fireplace poker" looking pieces of iron. He took some dents out of my mustang and I was amazed with the results and the best part is if there are no creases the paint all stays good. Just a thought I think it was listed under paintless dent removal.
www.dentdevil.com/index.html
1977 KZ650 B1.
1979 KZ650 B3
1976 LTD 900
1975 H1
1984 ZX750 Turbo (GPZ)
  • Aric
  • Aric's Avatar
28 Dec 2007 20:04
#186798
I just wasted 3 hours, 2 pounds of dry ice and countless kilowatts from the hairdryer. Almost no effect. It did take out some very, very small dings but didn't even touch the large, doughnut hole sized ones, and one medium , nickel size. It took my fresh primer right off with the rubbing (see video) so I wouldn't try it on fresh paint at all.
Gonna get some bondo.
  • saltydog
  • saltydog's Avatar
29 Dec 2007 03:36
#186819
I've always wondered what would happen if you filled the tank with water and then froze it. I've never had the nerve to try it. Maybe if someone had a spare tank, they could try it and report back.
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
  • saltydog
  • saltydog's Avatar
29 Dec 2007 03:38
#186821
  • 1982KZ1100D1
  • 1982KZ1100D1's Avatar
29 Dec 2007 05:37
#186832
With my luck it would still have the dents and split the tank at the seams.:blink: :ohmy:
