z750 twin specs?
  • iandz500
  • iandz500's Avatar Topic Author
z750 twin specs?
20 Nov 2007 15:52
#181904
what sort of power does a z750 twin kick out?
i might swap the z500 engine for a 750 twin but can't find out what power they are.
are they more torquey than the 4cylinder engines too?
thanks
iand
Bikes: 1960 lambretta Li125 sold; 2001 Honda CG125 sold; 2006 Yamaha FZ6 sold; 1980 Kawasaki Z500 sold; 1967 BSA Bantam D10; 2008 Aprilia Shiver sold; 2010 KTM Duke 690R; 1954 BSA Bantam; 1980ish Kawasaki Z200
  • Bluemeanie
  • Bluemeanie's Avatar
Re: z750 twin specs?
20 Nov 2007 15:53
#181905
Steel is the 750 twin man here, just hold tight and he'll pipe in. ;)
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
20 Nov 2007 15:55
#181906
The 750 twin is rated at 54 HP .. this would not be rear wheel hp .. No A Four will out run it many times over , Yes it is very torquy engine with a mild power curve , Very nice all around engine and bikes ,,
B) B)
Post edited by: Shoe48, at: 2007/11/20 18:58
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
20 Nov 2007 15:58
#181908
iandz500 wrote:
...i might swap the z500 engine for a 750 twin ...
You might be disappointed.
Low-end torque? Yes. Speed? No. Power over 4K RPM? No.
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • iandz500
20 Nov 2007 16:08
#181912
but my z500 only had 50hp to begin with, so i'd have thought the 54hp more torquey 750 twin could be as quick?
20 Nov 2007 16:19
#181919
I wouldn't make the swap.
KZ500 52HP @ 9000RPM
www.motorcyclespecs.co.za/model/kawasaki/kawasaki_z500%2079.htm
KZ750 (twin) 55HP @ 7000RPM
www.cyclechaos.com/wiki/Kawasaki_KZ750B
If I was going to go through all that trouble I sure would want more than a 3HP difference (and that's if the 750 is running like is was when it was new). I'll bet you could do better by fine tuning the engine you have. Ed
  • ronjones
  • ronjones's Avatar
20 Nov 2007 16:24
#181921
I don't know about that, Toast. I'm not saying they have the get up and go of a 4cyl, but mine seems to have plenty of pickup between 4&5K. Haven't had it, much, above 5K because @5 I'm hitting 70mph, and she just seems to get her wind @ 65. ;)
  • steell
  • steell's Avatar
20 Nov 2007 16:38
#181922
Forget it.
The KZ750 twin motor is much taller than the 500/550 motor, you would have to cut the main frame tube and raise it 2-3" just to get the motor in.
Not a good swap.
The 750 four motor is shorter than the 750 twin motor and would be a much better idea.
